Old Tue, May-29-2018, 12:19:45 AM   #21
dpaul
Reputation: 0 dpaul is on a distinguished road
Default Re: Comprehensive MSS60 DME Information
This KessV2 clone works fine and did not require any reworking or component replacement:
https://www.aliexpress.com/item/Unli...42424c4d7UX6kR
This Galleto V54 clone also worked fine without requiring any reworking.
Neither can read the ISN/SK. Both install an RSA bypass so that altered calibration files can be written.
Jump to top dpaul is offline   Reply With Quote
Old Tue, May-29-2018, 07:05:27 AM   #22
MartynT
MartynT's Avatar
Reputation: 0 MartynT is on a distinguished road
United Kingdom
Originally Posted by cossie1 View Post
Just wondering, if an FGTech V54 any good for reading / writing MSS60 ?
It works but I personally wouldn't use it, the software is way too flakey.
Jump to top MartynT is online now   Reply With Quote
Old Tue, May-29-2018, 10:48:21 AM   #23
dpaul
Neither Kess nor FGTech softwares are particularly well engineered. They are inflexible and glitches can occur. I've had them fail to complete or give error messages on a couple of occasions but nothing that simply re-running the session did not overcome.
If I was running any kind of business I probably would not use either clone but as a hobbyist I'm very happy.
Old Fri, Jun-01-2018, 09:42:22 PM   #24
cossie1
Reputation: 0 cossie1 is on a distinguished road
United Kingdom
Good to know it will work, yeh the software is pretty bad, but it can't see it doing any harm just getting a read.
Good to know that just restarting the process solves any issue's if it fails.
I have a mate with an originial Kess, so I could probably borrow that if needed, but as I have the FGTech clone already I just wondered if it would be any use with the MSS60.
Jump to top cossie1 is offline   Reply With Quote
Discussing Comprehensive MSS60 DME Information in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
