Old Sun, Mar-21-2010, 01:08:11 AM   #1
The Oregonian
The Oregonian's Avatar
Reputation: 0 The Oregonian is on a distinguished road
Default Interior trunk light - any fixes?
My interior trunk lights - the ones that are on the rear interior on each side, facing towards the front of the car, and which illuminate when the trunk is open - don't have good contact and won't stay on.
When I press them in they light, and they may stay that way for a few minutes. But they work their way free and don't stay 'connected' firmly enough to stay lit.
I have tried black duct tape, but it doesn'w work well...the really need to be pushed down (the duct tape doesn't hold firm enough). I'm sure I can come up with a way thru trial and error, but wanted to see if anyone has come across this and if there is a known solution.
Has anyone come across this and found a solution?
Tom
2005 Phx Yellow / Black
6MT (sold), Sunroof Delete, Manual Seats
Stepped Headers, CRT, ESS, AFE Elbow, TCK.
2004 Sterling Grey / Imola M3 (sold)
Jump to top The Oregonian is offline   Reply With Quote
Old Sun, Mar-21-2010, 01:11:44 AM   #2
jdl8r
Reputation: 0 jdl8r has disabled reputation
Originally Posted by The Oregonian View Post
My interior trunk lights - the ones that are on rear interior on each side, facing towards the front of the car, and which illuminate when the trunk is open - don't have good contact and won't stay on.
When I press them in they light, and they may stay that way for a few minutes. But they work their way free and don't stay 'connected' and therefore don't stay lit.
I had the same problem with mine... The two metal tabs weren't sitting properly against the circuit board to provide consistent power (the top one specifically). I had to basically press and pull upwards to un-lock the U-hook such that I could bend the connector up and out - and then reset it into the u-catch (no clue what they're really called). Anyhow, after doing that the lights seems to stay on when I open the trunk.
06 ZCP + Multifunction
Jump to top jdl8r is offline   Reply With Quote
Old Sun, Mar-21-2010, 03:36:53 AM   #3
Muscle
M is for Muscle
Muscle's Avatar
Reputation: 0 Muscle is on a distinguished road
Happened to mine as well. 1st time the right side, car was still under warranty, dealer replaced a new piece. 2nd time left side, I purchased a new one from Tischer, it was fairly cheap...
Factory Loaded ZCP 6MT SG / IR
OEM CSL / Dinan / Vorsteiner / KW / Rogue Engineering / Mason Engineering / Huper Optiks / UUC / Intravee
Jump to top Muscle is offline   Reply With Quote
Old Sun, Mar-21-2010, 04:03:26 AM   #4
The Oregonian
Do you happen to know part number? I looked online but couldn't locate it.
Thx
Tom
Old Sun, Mar-21-2010, 04:27:27 AM   #5
viper7180
Reputation: 0 viper7180 is on a distinguished road
Seems similar what I remember...having to bend the metal part which makes the connection. It's been a while since I did it, and now my led bulbs are bad so there's no light at all.
That's also a great sig picture. Do you have a link to a full size one?
'06 ZCP Interlagos Blue on Black
TFX Retrofit|Euro Headers-SuperSprint S-Res X-Race|Autosolutions 30%
Jump to top viper7180 is offline   Reply With Quote
Old Sun, Mar-21-2010, 08:25:35 AM   #6
AmirsM3
AmirsM3's Avatar
Reputation: 0 AmirsM3 is on a distinguished road
Wow mine just started doing this last week. I'm never in my trunk anyway so it doesn't bug me, but if it's a quick fix I'm down for this DIY.
2011 e90 M3 Space Grey DCT
2005 M3 SMG Convertible Jet Black : Depo Corners / DiCE SOLD
2007 350Z A/T Enthusiast Carbon Silver 296 rwhp 270 rwtq SOLD
2003 911S 6 Spd Guards RedStock
2010 Panamera Turbo Black PDK
Jump to top AmirsM3 is offline   Reply With Quote
Old Sun, Mar-21-2010, 04:10:54 PM   #7
opey
opey's Avatar
Reputation: 0 opey is on a distinguished road
mine do this too. i bent the metal tabs and it helped for a little while, but started doing it again. its just annoying
04 IR/IR 6spd
sold =(
Jump to top opey is offline   Reply With Quote
Old Tue, Mar-30-2010, 11:26:18 PM   #8
E46M3Rod
E46M3Rod's Avatar
Reputation: 0 E46M3Rod has disabled reputation
Wow. I actually came to search on how to turn the suckers off...not how to keep them on. Ha ha.
Every time I charge the battery I have to unclip and pull the housing out and disconnect the plug in. I guess it's not too much of a hassle but is there an easier way? Pulling the fuse? Not sure which one.
Do people connect the charger to the + - contacts under the hood vs that of the batter directly?
Do the interior trunk lights shut off automatically even with the trunk still open?
19x8.5F 19x10R Work Wheels RezaxII Toyo T1-R
Jump to top E46M3Rod is offline   Reply With Quote
Old Sun, Apr-25-2010, 03:40:02 AM   #9
BletzM3
Reputation: 0 BletzM3 is on a distinguished road
anyone know where to get replacements other than the dealer?
Jump to top BletzM3 is offline   Reply With Quote
Old Sun, Apr-02-2017, 08:04:53 PM   #10
JokerElite
JokerElite's Avatar
Reputation: 0 JokerElite is on a distinguished road
Default Re: Interior trunk light - any fixes?
To chime in for future reference, these do not need to be replaced in most cases. Bending the metal clips outward ensures a solid contact to the circuit board.
The lights should turn off when the trunk is closed.
1995 BMW M3 | 2004 BMW M3 | 2005 BMW X5 4.4i | 2009 BMW 328xi
Jump to top JokerElite is offline   Reply With Quote
fixes, interior, light, trunk
Discussing Interior trunk light - any fixes? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
