Old Tue, Oct-23-2018, 05:45:24 PM   #1
Louie0
Reputation: 0 Louie0 is on a distinguished road
Default Secondary Air Pump
Is there a straight forward means to deleting the Secondary Air Pump on a '98 M3 coupe? I need to pass smog checks (which will indicate fault codes) for a few more years. I can reset the codes before the tests, but when I installed a Schrick intake and missed replacing a hose properly, the SAP code would immediately recur.
Jump to top Louie0 is offline   Reply With Quote
Old Tue, Oct-23-2018, 06:33:02 PM   #2
Default Re: Secondary Air Pump
Why? You’re going to pay someone to tune it out (I’m not even sure it leaves a positive SAP status monitor), and possibly still fail visual. Just hook it back up.
Old Tue, Oct-23-2018, 07:26:20 PM   #3
propcar
propcar's Avatar
Reputation: 0 propcar is on a distinguished road
I removed it when it died on my '99 M3. I was doing an M50 mani swap at the time and wanted a tune anyways, so I got a TRM tune that eliminated the SAP check, never had an issue with emissions check in GA (no visual) and never any Check Engine light.
So:
Remove the SAP.
Buy the metal block off plate (I think it had a gasket too?) from BMW to plug the manifold port.
Put a rubber grommet that fits on that little hard vacuum line.
Get a good quality tune or just get a tune that eliminates the SAP.
Done.
Jump to top propcar is offline   Reply With Quote
Old Mon, Oct-29-2018, 10:24:30 PM   #4
///M325i
Reputation: 0 ///M325i is on a distinguished road
Would a tune pass 'plug in' emissions? Or does it just turn the CEL off.
Jump to top ///M325i is offline   Reply With Quote
Old Tue, Oct-30-2018, 02:29:59 AM   #5
LockDots
LockDots's Avatar
Depends on the tuner. Some delete the code altogether and others set it to always be "ready".
Jump to top LockDots is online now   Reply With Quote
Discussing Secondary Air Pump in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
