Old Tue, Oct-16-2018, 07:04:35 PM   #1
englishtom1596q
englishtom1596q's Avatar
Default M50 conversion
Hey guys,
Finally looking to install an M50 manifold on my car after holding onto it for...5 years. What is the general consensus on an install kit?
I've always looked at the CNC aluminum one that turner and others sell because of plug and play, keeping things in stock location etc. But I wonder if its really worth the premium over the m50manifold.com silicon hose setup?
https://www.turnermotorsport.com/p-3...52s52/?pdk=AAE
vs.
http://m50manifold.com//index.php?op...d=26&Itemid=40
Any thoughts from people who have either setup would be great.
Old Tue, Oct-16-2018, 08:06:47 PM   #2
Default Re: M50 conversion
The aluminum one takes up space and makes access under the manifold more challenging. I’d use a hose kit or make your own.
Old Tue, Oct-16-2018, 08:08:18 PM   #3
tofunin
Reputation: 0 tofunin is on a distinguished road
I went with the CNC aluminum one when I did mine as I am a fan of nicely machined parts and it being plug and play with the stock location. It is about a $100 difference and you don't get new vacuum lines but they are cheap to get from the auto parts store.
Jump to top tofunin is offline   Reply With Quote
Old Tue, Oct-16-2018, 08:31:25 PM   #4
Bimma360
Reputation: 0 Bimma360 is on a distinguished road
I can't quite recall, but I believe the M50manifold option requires some cutting to the bracketry for install. Whereas, the Turner option only needed a coolant pipe to be bent and you couldn't reuse one or both of the manifold support brackets. Either way, neither is 100% plug and play.
Ultimately, a few years ago, I went with the Turner option. Its a very high quality part that allows for factory mounting. Can't ask for more. Well you can... its the Schrick manifold.
E30 Dinan Turbo
Jump to top Bimma360 is offline   Reply With Quote
Old Tue, Oct-16-2018, 11:10:53 PM   #5
GG///M3
LOUNGE CREATOR
GG///M3's Avatar
Reputation: 0 GG///M3 is on a distinguished road
Albania
Ehhh the schrick manifold doesn’t flow better then the m50 manifold, and the thing it does better then the m50 is retain heat/heatsoak.
Jump to top GG///M3 is offline   Reply With Quote
Old Wed, Oct-17-2018, 12:05:55 AM   #6
Bimma360
Haha... I knew someone was going to chime in while I was writing that last part to my reply.
E30 Dinan Turbo
Old Wed, Oct-17-2018, 12:18:41 AM   #7
GG///M3
LOUNGE CREATOR
GG///M3's Avatar
Albania
Great minds
Old Wed, Oct-17-2018, 12:58:35 AM   #8
englishtom1596q
i actually was considering the shrick awhile ago when some randomly popped up for sale but could never justify the asking price.
Old Wed, Oct-17-2018, 01:58:14 AM   #9
tripitz
Reputation: 0 tripitz is on a distinguished road
I did the m50 kit. It did require some minor modifications to the brackets to make it work. Overall, the biggest issue was understanding the directions as to the some of the vacuum hoses and which brackets to use (I had both the OBD1 and OBD2 brackets and got into a long discussion whether we needed both for a car subjected to high Gs on track).
Overall it works. I've had a lot of tough hours on the car without issue on the kit this season.
Jump to top tripitz is offline   Reply With Quote
Old Wed, Oct-17-2018, 01:37:10 PM   #10
BMWManiac
Turbo 97 M3
BMWManiac's Avatar
Reputation: 0 BMWManiac is on a distinguished road
For that price, I would go with the m50manifold kit w/ the modified fuel rail cover. You won't ever see that pretty piece mounted and you don't need the sandwich plate with the proper size gasket that m50manifold provides....
1997 Artic Silver M3
CES Stage IV - 651rwhp/615rwtq@ 24 psi
Jump to top BMWManiac is offline   Reply With Quote
Discussing M50 conversion in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
