Old Mon, Dec-25-2017, 11:34:00 PM   #1
Ribar///M3
Ribar///M3's Avatar
Reputation: 0 Ribar///M3 is on a distinguished road
Default Help with few code, car died on me today...
I was driving and out of all days, car died on me today.
I had no luck starting the engine. Since it was 11F today, thinking maybe bad battery, i tryed jumping the car still no luck.
I ended up getting a pair of hands to push me, and while the car was moving i cranked the engine few times and finally got it going.
Finally got home and read the codes. And hoping you guys can give me some idea whats going on.
I tried starting the car few times after i got home and it starts every time.
That said, the most recent thing i done to the car is put a can of Liqui Moly 2007 Jectron Gasoline Fuel Injection Cleaner in the gas tank. As just maintenance thing to keep the car in good shape. Not sure if this had anything to do with it or not, i would hope not.
Also i had just under 1/4 of gas in the tank given that it was cold out i am not sure if may be fuel lines were frozen?
On to the codes:
8D - fuel level Pausibility
48 - Intake Camshaft Vasnos retard Valve 1
01 - Fuel Pump Relay
What i am getting from the above codes is maybe bad fuel pump relay or bad fuel pump? But if that is the case how would my car run? And its running as i am writing this? I would replace fuel relay if thats the problem but i though i would get some feedback if any of you had similer codes/problems?
Thanks
Ribar///M3
2004 M3 Carbon Black - 6MT
Jump to top Ribar///M3 is offline   Reply With Quote
Old Tue, Dec-26-2017, 12:36:49 AM   #2
PITT M3 RR
PA
PITT M3 RR's Avatar
Default Re: Help with few code, car died on me today...
Hm , can you check fuel pressure at the schrader valve? How many miles. The relay is much cheaper than the pump and easier. Could be good to do just because of age. When it’s not starting, can you hear the pump priming?
S54 E36 BUILD
Old Tue, Dec-26-2017, 01:27:45 PM   #3
Ribar///M3
Ribar///M3's Avatar
Originally Posted by PITT M3 RR View Post
Hm , can you check fuel pressure at the schrader valve? How many miles. The relay is much cheaper than the pump and easier. Could be good to do just because of age. When itís not starting, can you hear the pump priming?
I have not checked fuel pressure, where is shredder valve located?
Car has 126K on it. I hope its the Fuel relay, as you said easier and cheaper to replace, but i will have to test it first to make sure its in fact bad.
I ended up starting the car yesterday to warm it up, and i came back 10 min later and the engine was not running, so i am not driving it anywhere until i figure this out.
If its a bad fuel pump why does it run sometimes? I was under the impression fuel pump ether works or does not, there is no in between but i am not sure? I will also check to see if i can hear it prime up on starting the car.
Ribar///M3
Old Tue, Dec-26-2017, 05:05:07 PM   #4
11b4
11b4's Avatar
Edit: I didn't see you pulled the codes. Replace the green and black relay. AutoZone sells the green one for $20. The black one is $100 online. I got mine from a junk yard for $20
IF! The pump dies, buy a pump online, just the pump and replace it, instead of wasting $400+ on a whole OEM assembly when the pump is the only thing that goes bad. I just went through this last month when my car died on the highway
If you have a coupe the relays are in the trunk on the passenger side. If a vert it's behind the rear passenger card.
Last edited by 11b4; Tue, Dec-26-2017 at 05:13:34 PM. Reason: Read over the first post mentioning codes
Old Tue, Dec-26-2017, 05:09:42 PM   #5
TropicalM3
Reputation: 0 TropicalM3 is on a distinguished road
Jamaica
Maybe the fuel level might be the problem, the pump that pumps over the fuel from the left side of the tank to the right side(don't remember the correct name) might be bad so it is starving for gas. Put some gas in it and see what happens.
Jump to top TropicalM3 is offline   Reply With Quote
Old Tue, Dec-26-2017, 08:33:24 PM   #6
PITT M3 RR
PA
PITT M3 RR's Avatar
Schrader valve is on the fuel press reg assembly under the car , driver side, about where the door meets the fender. Under a metal cover.
Pumps can die slowly, but as stated, replace the fuel injection valve relay (green) and EKP relay black and test. No low voltage codes right?
S54 E36 BUILD
Old Tue, Dec-26-2017, 10:55:52 PM   #7
Ribar///M3
Ribar///M3's Avatar
Update: I pulled the two Fuel Pump Relays out.
I tested the green one and it working. I applied 12V to the two input pins and checked the connectivity on the output pins that would send the power to fuel pump and its working. I can hear the relay click as i energize it, and i can see the continuity established at that point on the output pins, which is what i would expect to see.
That said the black one i need your help with. I did not see any circuit diagram for the black one, so i am not sure which pins need to be energized for it to work and which pins are providing the 12V to the fuel pump? I been googling but no luck finding any diagrams for it.
The black relay has 8 pins, each has a number next to it, in this order 1, 2, 4, 5, 6, 7, 8.
It was really cold today, i could not stay in the car to long to do more testing, but hope someone can shed some light on the black relay, and i can try to test it if its working or not.
Here is the picture for reference on both black and green relay.
Thanks!
Ribar///M3
Old Tue, Dec-26-2017, 11:04:46 PM   #8
PITT M3 RR
PA
PITT M3 RR's Avatar
Pin 8 is hot in run and start
Pin 7 is ground
Pin 6 is hot at all times
Pin 2 sends power to pump
Pin 1 goes to DME (signal comes from DME)
Here’s the ETM of the Z3M (very similar to E46M) same DME / engine management. Save it, it comes in handy.
2001 Z3M ETM
File Type: png 072D8485-F74B-4B3E-8150-DD12F05BAF47.png (174.7 KB, 19 views)
S54 E36 BUILD
Old Tue, Dec-26-2017, 11:56:53 PM   #9
e46Dan
Reputation: 0 e46Dan is on a distinguished road
Fuel pump might be on its way out. Usually it starts popping fuses before it goes though.
Jump to top e46Dan is offline   Reply With Quote
Old Wed, Dec-27-2017, 12:00:12 AM   #10
Ribar///M3
Ribar///M3's Avatar
Thanks for that diagram very helpful to understand. So here is a quick update, and unless i messed up my wiring i think the black relay is bad.
Also note, i forgot to mention in above post, that there is one more pin 9 on black relay. But looking at that diagram you posted i dont see a reference for it, so maybe its irelevant but i though i would mention it here.
So this is how i tested, i added 12V across Pin 8 and 7 (Timed Hot and Ground)
I was measuring voltage across pins 2 and 7 (Hot to Fuel pump and Ground) i was expecting to see 12V here on these pins when relay is energized, but instead get 0V
I then added 12V across pins 6 and 7 (Hot at all times and Ground)
Then measured voltage on pins 2 and 7 (Hot to Fuel Pump and Ground) and here i get 3.8V (But expecting to see 12V?)
I could be doing this all wrong so please let me know if i am messing my connections to test this.
Ribar///M3
Discussing Help with few code, car died on me today... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
