Old Sat, Dec-11-2010, 09:17:17 PM   #21
kuksul08
I'll be picking these up soon. $1.91 each at the local dealer but not in stock.
Old Thu, Dec-16-2010, 10:22:30 PM   #22
OGGM3
occasional user
Reputation: 0 OGGM3 is on a distinguished road
Great DIY and I've had these bolts back on me before. My friend tighten it up for me but it just got lose again. The M3 did make a loud clunking noise due to the loose diff bolts. I'll definitely look into buying the upgraded bolts. Mines backed out the first time from taking my M3 to the track. The wheel hops progressively loosened the bolts and so did some donuts.
Jump to top OGGM3 is offline   Reply With Quote
Old Fri, Dec-17-2010, 04:29:37 AM   #23
chalaka
Reputation: 0 chalaka is on a distinguished road
Taiwan
can anyone share a bit more information on the sad accident? so the jack stand isn't enough? hmm .. it got me scared since i used to use only 2 3TON jack stand when getting down there >"<
Jump to top chalaka is offline   Reply With Quote
Old Fri, Dec-17-2010, 06:25:37 AM   #24
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
It was one of the guys on svtperformance.com. He was changing the clutch on his whippled cobra and it shifted and dropped on him. Neighbors heard him calling for help and called 911. By the time they got the car off of him he was already gone. It was really sad.
Just have a couple "back up's" I always have a jack next to me that is not holding up the car, but basically giving it something to fall onto other than me. I use boards under the wheels when they are on and put the wheels under the car when they are off with a towel over them. It protects the faces of them from little things, but obviously not a car falling on them. A car is a car. Replaceable. Lives are not. I am over cautious (if that is possible) when working under cars.
2004 IR Slicktop
Jump to top suaveflooder is offline   Reply With Quote
Old Fri, Dec-17-2010, 09:05:24 AM   #25
chalaka
Taiwan
thanks, Suaveflooder ..for filling me in with the details ..
man it's truly a sad thing to hear about ..
i'll make sure i purchase more jack stand then .. and adapt your backup plans ..
Old Fri, Dec-17-2010, 12:07:55 PM   #26
It's been over a year since I did this, but for some reason I remember there being 3 bolts. Am I crazy?
Nice DIY, btw
Old Fri, Dec-17-2010, 05:36:53 PM   #27
Wengy
Reputation: 0 Wengy is an unknown quantity at this point
OP, great DIY. I'm surprised no one else (that I've read) has fingered these bolts as the likely suspect for the clunk.
Jump to top Wengy is offline   Reply With Quote
Old Fri, Dec-17-2010, 06:43:38 PM   #28
suaveflooder
I have 4 jack stands, a set of wheel stops and two jacks. All in a one car garage. that makes things SUPER inconvenient, but it keeps me safe
Nice DIY, btw
I only saw two, but I might get back under there and take a look just in case I missed one
Agreed. Like I said, it's still there, but way less.
2004 IR Slicktop
Old Thu, Dec-30-2010, 10:24:20 PM   #29
niacin
Reputation: 0 niacin is on a distinguished road
Default Re: Differential Bolts replacement DIY: updated bolts
Nice DIY, btw
You're right, there's a 3rd bolt at the front of the differential. It's securing the diff to the diff carrier with a rubber bushing. It's the bolt #9 in this illustration:
http://bmwfans.info/parts/catalog/E4..._axle_carrier/
The rear bolts are #10 in the illustration.
I heard that it's a PITA to get to the front bolt though. Maybe some people who tried to change or tighten the front bolt can chime in.
Jump to top niacin is offline   Reply With Quote
Old Sun, Jan-02-2011, 02:39:02 AM   #30
802Hoop
is in the hizouse
802Hoop's Avatar
Reputation: 0 802Hoop is on a distinguished road
a fully threaded bolt is often times weaker than a partially threaded bolt like the replacement ones shown in the OP's photos. There is more material and not nearly as many crack prone spots created by the threads... also, they could very well be made of a stronger steel.
"I don't care how much you upgrade your car, if you don't get your ass out on the track, your money is going to waste and your modifications mean nothing."
CCW Classics, Autosolutions 40%, Bimmerworld brake bushings, PFC DD rotors, PFC 11 pads, SS lines, Dinan intake/MAF, Dinan Stg 3 Software, Tubi midpipe, Dinan muffler, Dinan Monoballs, Dinan Stg 3 Suspension, Turner Sway Bars, Full powerflex bushings, Turner Adj. LCA w/ spherical bearings, full Bimmerworld suspension bearings, HPF reenforced subframe, function 7 guibo
Jump to top 802Hoop is offline   Reply With Quote
bolts, differential, diy, replacement, updated
Discussing Differential Bolts replacement DIY: updated bolts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
