Old Mon, Apr-11-2011, 05:36:31 PM   #31
roarf
Jimmies: Not Rustled
roarf's Avatar
Reputation: 0 roarf is on a distinguished road
Default Re: Differential Bolts replacement DIY: updated bolts
Thanks for the DIY, I have the bolts and plan on doing this soon. I just have one question...
How would I go about getting the right torque value on these bolts if I have to hold the torque wrench at an angle? Don't you have to calculate a different torque value based on the angle of the wrench or something like that?
'14 Evora S - Chrome Orange/Ebony
'02 M5 - Carbon Black/Silverstone
'01 M3 - Imola Red/Black
Jump to top roarf is offline   Reply With Quote
Old Mon, Apr-11-2011, 09:07:59 PM   #32
tonggi
Tonggi Tuning, LLC
tonggi's Avatar
Reputation: 0 tonggi is on a distinguished road
funny I just did this yesterday. I didnt jack up the diff since I did one side at a time. It wasn't a problem. I did some blue loctite to be safe (solid bushings, I dont want them vibrating out)
TiTS Racing in association with MMFN Racing and AYO STFU
Want to buy your High Mileage Car!
Jump to top tonggi is offline   Reply With Quote
Old Mon, Apr-11-2011, 11:51:25 PM   #33
matadorCE
Reputation: 0 matadorCE is on a distinguished road
Thanks for the DIY, and specially pics of the tools you used. I tried tightening those bolts before but wasn't sure how to go about it due to the ackwards angles.
Jump to top matadorCE is offline   Reply With Quote
Old Tue, Apr-19-2011, 08:15:04 PM   #34
roarf
roarf's Avatar
If I have to hold the torque wrench at an angle in order to access the bolts, do I have to account for that in the torque value somehow? Or do I just set it to 61 ft*lbs and go?
Old Tue, Apr-19-2011, 08:20:41 PM   #35
dtiffan2
dtiffan2's Avatar
Reputation: 0 dtiffan2 is on a distinguished road
If you are using the torque wrench on an angle some of the force will not directly translate to rotating the bolt, so I would just put the torque wrench a few ft-lb higher and call it a day. A couple ft-lb one way or another isn't going to make a significant difference, especially when torque values are around 60 ft-lb.
Jump to top dtiffan2 is offline   Reply With Quote
Old Fri, Apr-22-2011, 05:54:10 PM   #36
roarf
roarf's Avatar
Edit: Nvm. I re-used the washers.
As I pulled the first bolt out, I saw that it was already the updated bolt. Oh well, I already had started loosening it so I just changed them anyways and put a little blue loctite on the new bolts. For the record, neither of them were loose. And the front mounting bolt you can't even see because of things in the way, but you can just barely feel it. I could not feel any looseness in the front bolt.
Old Sat, May-07-2011, 06:19:20 PM   #37
spr12
Reputation: 0 spr12 is on a distinguished road
Pretty sure the torque settings are wrong. TIS has them at 200nm front and 20nm joint torque and 90 degree torque angle for rear as it is an e46/s54.
Also have you ispected the bushings? They are rubber and there is a removal install procedure in the TIS...
1AZ Final drive to rear axle carrier
E46 / S54, E85 / S54, E86 / S54 Front Observe repair instruction. 200 Nm
rear:
E46 / S54, E85 / S54, E86 / S54 Rear Observe repair instruction.
Jointing torque 20 Nm
Torque angle 90
2005 M3 ZCP with every option...
Jump to top spr12 is offline   Reply With Quote
Old Sat, May-07-2011, 06:33:16 PM   #38
I M Legend
Can someone post the part# for the new bolts, thanks!
Old Sat, May-07-2011, 09:22:39 PM   #39
spr12
Sorry misread TIS. See updated correct values above... Doh! Unless the new bolts come with different torque specs... Did they tell you the torque is different when you bought the bolts?
Old Sun, May-08-2011, 02:22:19 PM   #40
roarf
roarf's Avatar
From the original post...
- revised bolts (2) part number 23 00 1 222 891
bolts, differential, diy, replacement, updated
Discussing Differential Bolts replacement DIY: updated bolts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
