Old Wed, Jan-10-2018, 02:40:28 AM   #261
rovert604
rovert604's Avatar
Default Differential Bolts replacement DIY: updated bolts
Didnít have a problem with clearance or space at all. Just take off the one 7mm hex screw holding on the plastic shield for extra flexibility.
V-Brace is still tight on the car!
--Trevor in 604--
Vancouver, BC, Canada
Old Wed, Jan-10-2018, 02:45:50 AM   #262
Mystical
Mystical's Avatar
Reputation: 0 Mystical is on a distinguished road
Default Re: Differential Bolts replacement DIY: updated bolts
Originally Posted by Msidd View Post
There's room and possible..took a pic for you guys.
You can take the guards and v brace if needed not really necessary.
Sent from my SM-G930T using Tapatalk
Cool. Never looked at it from that angle. Thanks for the pic!
Jump to top Mystical is offline   Reply With Quote
Old Wed, Jan-10-2018, 03:41:13 AM   #263
mrgizmo04
mrgizmo04's Avatar
Pretty cool. I usually take half the car apart for whatever I'm doing and combine jobs, so never looked at it from such a simple perspective.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Jan-10-2018, 05:01:30 AM   #264
rovert604
rovert604's Avatar
Also this is how high I needed that corner to get decent leverage to torque down the front diff bolt.
A reminder...Just like the first post, have safety as your top priority when under the car.
--Trevor in 604--
Old Fri, Jan-12-2018, 06:57:10 PM   #265
wolffbimmer
Reputation: 0 wolffbimmer is on a distinguished road
Clarification on the torque for these rear bolts? This thread says 61 ft/lbs however others are stating 15 ft/lbs plus a 90 degree turn.
http://sawashie.free.fr/M3/TorqueSpe...SPECS%20LR.pdf
PDF above states 15 ft/lbs and the 90 degree turn. I think this thread should be updated accordingly as many folks will see it and choose 61 without thinking.
Jump to top wolffbimmer is offline   Reply With Quote
Old Sun, Jan-21-2018, 02:19:04 PM   #266
mrgizmo04
mrgizmo04's Avatar
There are 2 camps. 1) use 15 and then 90 degrees, 2) get to ~60 right away. End torque is about the same.
'05 M3 6MT coupe
bolts, differential, diy, replacement, updated
Discussing Differential Bolts replacement DIY: updated bolts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
