Old Mon, Feb-10-2020, 02:44:29 PM   #1
Default Brake reservoir won't hold pressure?
I got my Motive pressure bleeder out for the first time, and in doing a pressure test I noticed the system would get to ~15 PSI fine, but after a few minutes the gauge would slooowly drop down.
Is this normal? I was worried there was a leak, but I looked around the car, didn't see any drips, no dripping under the reservoir or inside at the clutch master.
Figured I would ask here since folks bleed their brakes more regularly.
Old Mon, Feb-10-2020, 03:49:12 PM   #2
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Reputation: 0 CrookedCommie is on a distinguished road
Bulgaria
Default Re: Brake reservoir won't hold pressure?
Sounds normal. Mine leaks somewhere at the cap or the Motive hoses, not the car's system. It holds enough to bleed without any issue though.
Jump to top CrookedCommie is online now   Reply With Quote
Old Mon, Feb-10-2020, 04:52:15 PM   #3
ThunderMoose
Normal
#67 2019 NASA National TT3 Champion; 2017 NASA TX TT3 Champion
FLMS Half Cage, RaceTech 4009HR drivers seat, Schroth 6-Pt Harness, E.S.S. Fire System, AIM SOLO DL with ECU Harness, SmartyCam, Angle Aluminum with VAC dead pedal, Sparco Steering Wheel on MOMO hub, MCS 2W NR, Hyperco 700F 800R springs, Hotchkis Front and Rear Sway bars, Vorshlag Camber Plates, Turner ARCA, AJ Hartman Front Splitter, BW V2 Wing, BW CF Rear Diffuser, APEX ARC-8 wheels, Brembo BBK Front, Carbon Fiber Roof, CF Headlight Blanks, Door Windows and Cards Delete, TMS rear and front subframe reinforcement, Zionsville Competition Cooler, BW Oil Cooler, Oil Diverter Valve, Motorsports Thermostat, Evolve CF Intake, Epic Stepped Headers, Turner Pulleys, BW 3.5" Race Exhaust, EPIC Alpha N Tune, Beisan Oil Disk and Vanos Seals, ZF 5MT, CAE Ultra Shifter
Jump to top ThunderMoose is online now   Reply With Quote
Old Mon, Feb-10-2020, 06:32:00 PM   #4
Fastboy
Fastboy's Avatar
Reputation: 0 Fastboy is on a distinguished road
Check the O ring in the cap. Mine developed a crack in the O ring and did the same.
Jump to top Fastboy is offline   Reply With Quote
Old Mon, Feb-10-2020, 06:33:59 PM   #5
aeronaut
aeronaut's Avatar
Reputation: 0 aeronaut is on a distinguished road
What they said. Nothing to fix.
Jump to top aeronaut is offline   Reply With Quote
Old Mon, Feb-10-2020, 09:33:12 PM   #6
The cap is supplied by Motiv in this scenario
Thanks for the reassurance, guys! I'm excited to see if bleeding the ABS feels any different on track
Old Tue, Feb-11-2020, 04:15:55 PM   #7
ethan
Reputation: 0 ethan is on a distinguished road
Mine usually holds well (long enough to bleed without repumping), but I left some fluid in it for a little too long and found that the flapper on the bottom of the pump started to fail. Cheap replacement from Motiv though.
Build Thread | Instagram
Jump to top ethan is offline   Reply With Quote
Old Thu, Feb-13-2020, 09:04:37 AM   #8
duracellttu
I think fast, I talk fast and I drive fast...
Reputation: 0 duracellttu is on a distinguished road
I experienced the same issue and it ended up being the inline hose connector between the main unit and the line connecting the cap. Not sure what specific setup you have. Mine was purchased through ECS and I opted for the aluminum cap which was a separate piece with its own hose and threaded connector that attached to the main units hose. If your is similar try using some nylon tape to make a better seal.
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Restoration: RKP CF Roof Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion+MAP Sensor | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams+DLC Coated Followers | CSL Karbonious Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Jump to top duracellttu is online now   Reply With Quote
Old Thu, Feb-13-2020, 06:18:23 PM   #9
Yup. I did this job last night and that turned out to be the issue. During the "pressure test" there wasn't any hissing or anything, but while bleeding it would slowly weep out of that NPT fitting. I gave it some ugga-duggas and it helped quite a bit
Bleeding the ABS was super easy. I was concerned about how much fluid the process takes so I got 2L of SRF.. turns out I didn't need that second liter, but live and learn. Excited to see if this helps brake feel on the limit
Old Thu, Feb-13-2020, 06:59:05 PM   #10
nholmes
Track Junky
nholmes's Avatar
I had an issue with the cap not sealing. Are you sure your reservoir is seated fully into the master?
Check out my build!
Originally Posted by Nate047 View Post
Are you feeling loose in the rear end currently?
Discussing Brake reservoir won't hold pressure? in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
