Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > Regional M3's > Southeast
Southeast For events in Alabama, Arkansas, Florida, Georgia, Kentucky, Louisiana, Mississippi, North Carolina, South Carolina, and Tennessee.
Old Sat, Nov-02-2019, 05:09:22 PM   #41
Dirty Elf
BSME
Dirty Elf's Avatar
Reputation: 0 Dirty Elf is on a distinguished road
Default Re: Looking For Someone To Bulletproof My Vanos - Orlando FL
id like to do my vanos too, time is a little sparse for me with a newborn in the house.
if you guys do end up getting together let me know
First Road Trip
2004 Silver-Grey ///M3 Coupe
Jump to top Dirty Elf is offline   Reply With Quote
Old Mon, Nov-04-2019, 12:01:09 AM   #42
Race M3
They don't think it be like it is, but it do.
Race M3's Avatar
Reputation: 0 Race M3 is on a distinguished road
I have all of the Bmw special tools and such from when I was a bmw tech...Iím in north Florida and donít mind helping here and there. Timing the vanos is very easy once youíve done a few. Also can fix solenoids as well. (Broken solder joints)
Jump to top Race M3 is online now   Reply With Quote
Old Mon, Nov-04-2019, 12:08:42 AM   #43
bmwahba39
bmwahba39's Avatar
Reputation: 0 bmwahba39 is on a distinguished road
Awesome! Iíll pm you and see if we can set a meet or something up one of these weekends.
1997 E36 M3 - Boston Green/Modena
2003 E46 M3 - Alpine White/Impulse Cloth 6MT
Jump to top bmwahba39 is online now   Reply With Quote
Old Tue, Feb-11-2020, 02:21:16 AM   #44
jixer77
Reputation: 0 jixer77 is on a distinguished road
Hey guys Iím in Orlando by the airport. Would love to meet up with some locals. Iíve had ATH do my subframe reinforcement and now looking to bulletproof Vanos.
Jump to top jixer77 is offline   Reply With Quote
Old Tue, Feb-11-2020, 03:15:29 AM   #45
F1Dryvr
Reputation: 0 F1Dryvr is on a distinguished road
Ive done all this stuff at home, but im in melbourne. i could possibly help.
Jump to top F1Dryvr is online now   Reply With Quote
Old Tue, Feb-11-2020, 02:34:51 PM   #46
.'s Avatar
Reputation: 0 . is on a distinguished road
I'm in the north Orlando area and done a few locals vanos at this point. You can hit me up directly if you'd like a hand or you can drop your car off with Curtis at WTF Motorsports and I'll come in and do it.
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, 36lb injectors, Hassan tuned, APE Flex fuel kit, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5Ē twin-piped resonated section 2, SGT scza section 3.
Drivetrain: DKM Stage 2 Clutch, E60 Shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Ohlins 3DM ďtrack dayĒ kit, RE strut bar, AKG RSM's, UUC front sway bar, BW camber arms, TMS monoball RTABs, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware stud kit.
Interior: Cobra Nogaro seats, alcantara headliner, BMW Performance pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is online now   Reply With Quote
Old Tue, Feb-11-2020, 03:30:54 PM   #47
bmwahba39
bmwahba39's Avatar
Hell yeah! Vouch for this guy.
I actually bought a rebuilt vanos unit from Anthony from the FS section. It comes preinstalled with all the anti-rattle and all the other bits. I had PSI install it.
It turned out to be cheaper that way since I didnít really pay for the vanos rebuild labor just remove and replace. That might be another option.
Old Tue, Feb-11-2020, 04:35:43 PM   #48
akagc
Reputation: 0 akagc is on a distinguished road
Just chiming in to put in a good word for Curtis at WFT Motorsports.
I went to Curtis in 2015 to get my s54 refreshed. He completed inspection 2, valve adjustment, valve cover gasket, fuel filter, new rotors, pads and sensors all around, differential seals, differential flush, brake and transmission flush, fuel pressure regulator, fuel filter, cpv valve, spark plugs, hoses and a few other things to get the car as close to OE spec as possible.
I had him also inspect the vanos while in there because I wanted to get the besian parts to have him bulletproof it; but after inspection, he said my vanos didn't need to be touched because it looked perfect and everything looked tight ... no play between the hub and oil pump disc, no leaks on the steals etc. He did replace the cam bolts for good measure.
When I picked up the car everything was flawless. Pulls hard and smooth, no rattles or leaks of any kind. Car had 66k miles in 2015 when Curtis serviced it, and now has 68k and change. It's a weekend driver (I don't drive a lot to begin with). For reference the car is 06 ZCP. Prod: 10/2005.
I may eventually buy a rebuild vanos and have it installed by him or a local DIYer or PSI (they are good too) if the car begins to show signs, but for now I'm comfortable with Curtis' assessment. Curtis is responsive, stands by his work and is always available to help.
- 04 Silver (tiag) ZHP 330i
- 06 Silver Grey ZCP M3
- 02 Black Civic. Beater
Jump to top akagc is offline   Reply With Quote
Old Tue, Feb-11-2020, 06:31:34 PM   #49
Race M3
Race M3's Avatar
FYI if you guys have the vanos apart, do it all....otherwise youll be pulling it back apart agian. do the rattle kit, guide, bolts. everything.
and buy parts from fcp. its about $350 to do it right with oem seals/gaskets. every time if you buy elsewhere
Discussing Looking For Someone To Bulletproof My Vanos - Orlando FL in the Southeast Forum - For events in Alabama, Arkansas, Florida, Georgia, Kentucky, Louisiana, Mississippi, North Carolina, South Carolina, and Tennessee. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
