Old Fri, Dec-21-2007, 02:51:17 AM   #21
Originally Posted by JeST View Post
You're right it is preventative maintenance. I've seen a lot of cases of the plug leaking for some reason though.... Maybe its a northeast thing?
idk. Something else to look forward to
Old Fri, Dec-21-2007, 03:33:33 AM   #22
m3 hal
Reputation: 0 m3 hal will become famous soon enough
Tranny and diff fluid are speced by BMW to Service 2... the same people that spec oil changes at 15k. The cost of changing the fluids vs the cost of a tranny/diff is significant enough that I think it's worth changing the fluids twice as often
I've ever heard of any tranny/diff failure that would have been prevented by changing the fluid sooner. It always seems that those types of failures are the result of some catastrophic internal failure. Not saying that they are lifetime fluids, but for a daily driver I don't think 60k miles is an unreasonable interval.
Jump to top m3 hal is offline   Reply With Quote
Old Fri, Dec-21-2007, 06:42:13 AM   #23
gary_youngster
//|Power
gary_youngster's Avatar
Reputation: 0 gary_youngster is on a distinguished road
thanks ...this is a great thread... good job and im reserving it.!! =)
Jump to top gary_youngster is offline   Reply With Quote
Old Fri, Dec-21-2007, 07:21:21 AM   #24
tilolite
tilolite's Avatar
Reputation: 0 tilolite is on a distinguished road
Haiti
I think that in the DYI list, we should also list alternative and reputable products to OEM that many here have successfully used. For instance for tranny or diff oil change, Royal Purple or Redline have been used at a fraction of the cost of the BMW lifetime fluid. Make sure to include the normal legal disclaimer.
Jump to top tilolite is offline   Reply With Quote
Old Fri, Dec-21-2007, 07:26:16 AM   #25
link me to specifics and I'll add a note about it
Old Fri, Dec-21-2007, 02:50:16 PM   #26
Bents
Reputation: 0 Bents will become famous soon enough
England
This isn't routine maintenance, but do you know where to find an alternatore replacement DIY? I have heard of many failures around 50k
It would also be nice if anyone has a DIY for coolant flush and/or power steering fluid flush.
Originally Posted by Wayward View Post
Had enough of this forum. Thanks guys.
5/24/14:
Iím posting one last time.
Jump to top Bents is offline   Reply With Quote
Old Fri, Dec-21-2007, 03:28:20 PM   #27
Need4Spd
Need4Spd's Avatar
Reputation: 0 Need4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond repute
Thanks for doing this, Ian. Let's keep this on the main board for now so everyone has a chance to see it. I can make it a sticky after some reasonable time (Ian, maybe PM me when you think of it so I don't forget).
Most BMW magazines seem to recommend swapping out water pumps and thermostats at around 60k miles as a preventative measure. IDK if e46 M3s are prone to the same failures or not.
Another thing to think about is the MAFS. They insidiously degrade over time, robbing you of power. This seems less a problem on e46 M3s than e39 M5s but they're the same design. MAFS tend to foul more readily when you run "oiled" filters rather than OEM paper, at least on M5s they do.
Past car: '05 M3 'vert, 6MT, custom 18" RAC RG63 Hyperblack monolites, Continental Extreme DW 245/40 and 275/35, Nav, HK, BT, Euro rotors, Custom Performance Rasp Terminator (2nd Gen.), Silverline DICE iPod adapter, EAS Aurora 60 LED Angel Eyes, "-CDV," "free & easy" camber mod (-1.7 degrees), Koni S/A shocks, Rogue Engineering RSMs and transmission mounts, Bimmerworld silicone intake boot, spacesaver spare from LeatherZ, updated OEM RTABS
'11 Jaguar XFR
Jump to top Need4Spd is offline   Reply With Quote
Old Fri, Dec-21-2007, 05:24:06 PM   #28
tilolite
tilolite's Avatar
Haiti
Here's the link for an e46 coolant change. It's not an M3 but it should be the same procedure.
http://www.bmw325i.net/maint_coolant_change.shtml
Old Fri, Dec-21-2007, 05:34:07 PM   #29
added, thanks
Old Fri, Dec-21-2007, 07:04:26 PM   #30
Jasoncor
Grumpy Young Man
Reputation: 0 Jasoncor has a spectacular aura about
subscribed
Jump to top Jasoncor is offline   Reply With Quote
e46, getbmwparts.com, maintenance, thread, tischer
:: ECS Tuning :: Selection of E46 M3 Maintenance Products and Service Kits ECSTuning M3Forum Sponsor Announcements and Specials 1 Wed, Sep-24-2008 06:21:18 PM
E46 maintenance / DIY support ? jav1 E46 M3 (2001-2006) 19 Tue, Aug-21-2007 05:29:00 AM
FS: 2002 E46 M3 (SMG) - CPO/Extended Maintenance (BMW Individual) NoSoup4U Parts for Sale/Wanted 6 Thu, Jun-29-2006 09:14:08 PM
The Preventative Maintenance Thread Obioban E46 M3 (2001-2006) 1 Tue, Jul-05-2005 11:38:25 PM
E36 M3 vs. E46 328Ci -- Maintenance Costs gdhyde E36 M3 (1992-1999) 13 Sat, Dec-11-2004 07:23:39 PM
Discussing e46 M3 Maintenance Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
