Old Thu, Dec-07-2017, 01:35:23 AM   #11
NolliM3
NolliM3's Avatar
Default Re: Bought new Used 97 M3 - Keys arent matching
Originally Posted by dunkman23 View Post
what if he got a new cylinder/key and just did an EWS Delete chip? is that possible?
The EWS delete is just breaking the link between the EWS and the DME...so even if one gets new cylinder/key, they would need to align with EWS.
Old Thu, Dec-07-2017, 03:26:23 AM   #12
bluptgm3
Default Bought new Used 97 M3 - Keys arent matching
My thought here is that Dealer key(s) would be sourced to the VIN, containing a chip code pre-coded within the EWS, a total of 10 codes. The tumbler assembly would also be VIN matched to the keys. Tumbler does not play a roles in key, EWS, ECU ‘conversation’, but the antenna ring located on the tumbler does.
Old Thu, Dec-07-2017, 12:35:07 PM   #13
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Originally Posted by bluptgm3 View Post
My thought here is that Dealer key(s) would be sourced to the VIN, containing a chip code pre-coded within the EWS, a total of 10 codes...
Your thought is spot on (exactly right).
4 keys come with the car, (thus) you can order up to 6 spares. After that you would need a new EWS2 unit (through the official way)
Old Thu, Dec-14-2017, 01:12:55 AM   #14
dunkman23
dunkman23's Avatar
Reputation: 0 dunkman23 is on a distinguished road
So I ordered a new OEM Vin matching key from BMW. This Key now opens glove box, trunk, and passenger side door. It doesn't start the car unfortunately. I pulled out the DME/ECU and it matches the the cars Vin. Do you guys think just swapping out the Tumbler to match the OEM Key would fix this issue?
Sent from my Pixel XL using Tapatalk
2002 BMW ///M3 6mt TiAg /Imola - APEX ARC-8/PSS - BILSTEIN PSS10
1993 BMW ///E34 Touring - OBD1 S52 - 5sp MT, 3.23 LSD - SOLD
1997 BMW ///E36 Sedan -
2012 BMW ///E70 MSport -
Jump to top dunkman23 is offline   Reply With Quote
Old Thu, Dec-14-2017, 01:38:45 AM   #15
bluptgm3
The key rotated but the engine does not crank …or…the new factory key does not rotate the ignition tumbler?
If the former, located the EWS and validate it has your VIN.
If the later, check the EWS for a VIN also but you may be in for a whole round of fun.
Old Thu, Dec-14-2017, 02:10:42 AM   #16
Texaz3
New key needs to be learned by the car, I believe
Old Thu, Dec-14-2017, 02:33:16 AM   #17
dunkman23
dunkman23's Avatar
New factory key doesn't rotate. I compared the key the previous owner gave me that started the car and the new OEM Factory key... They are different keys
Old Thu, Dec-14-2017, 02:34:06 AM   #18
dunkman23
dunkman23's Avatar
New key doesn't even rotate in the tumbler.
Old Thu, Dec-14-2017, 02:34:46 AM   #19
dunkman23
dunkman23's Avatar
Any idea where ews is located at?
Old Thu, Dec-14-2017, 02:53:34 AM   #20
bluptgm3
I believe in the dash behind the glovebox. Simple google search revealed a couple of diagrams and videos. There is one additional component in left side foot well (US driver side) - a simple analog to digital converter.
Discussing Bought new Used 97 M3 - Keys arent matching in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
