Old Mon, Oct-14-2019, 10:50:12 PM   #1
djpfine
Reputation: 0 djpfine is on a distinguished road
Default Camshaft maintenance
Car is in for a valve adjustment, and my mechanic noticed some writing by the camshaft bearings. This doesn't look stock. What kind of work/modifications would involve writing like this?
Imgur link: https://imgur.com/fOeoL6z
Jump to top djpfine is offline   Reply With Quote
Old Mon, Oct-14-2019, 11:14:39 PM   #2
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
Default Re: Camshaft maintenance
Looks like the photo isnt working.
My '02 E46M Build Thread
Jump to top robgill is online now   Reply With Quote
Old Tue, Oct-15-2019, 03:21:35 AM   #3
cudzich09
cudzich09's Avatar
Reputation: 0 cudzich09 is on a distinguished road
Poland
http://i.imgur.com/fOeoL6zl.jpg
open without https, loads fine.
Currently in the garage:
-2002 Coupe M3 Manaual
-1997 540i Manual
-2001 Eurovan, camper conversion
Jump to top cudzich09 is offline   Reply With Quote
Old Tue, Oct-15-2019, 03:23:38 AM   #4
djpfine
Strange...seems to work fine on desktop, but the images don't show up in-line on mobile. Should be fixed now with the direct link below.
Old Tue, Oct-15-2019, 02:21:14 PM   #5
chalaka
Reputation: 0 chalaka is on a distinguished road
Taiwan
maybe the mileage noted down when the cam or something related was changed ..
Jump to top chalaka is offline   Reply With Quote
Old Tue, Oct-15-2019, 02:32:40 PM   #6
HassanEido
HassanEido's Avatar
Lebanon
i've similar stuff done by shops to note valve adjustment and the like.
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Tue, Oct-15-2019, 03:31:55 PM   #7
DanAvoN7
Reputation: 0 DanAvoN7 is on a distinguished road
Mechanic must be new to working on S54's They all have that unless it's been scrubbed clean or covered in oil residue. That writing is from the factory and a matching number will be written on the cylinder head on the lip just in front of where the vanos mates up. It's to make sure the correct thrust bearing flange goes with the correct cylinder head during the machining process.
04 BMW M3 6spd - Alpine White/Black
Apex ARC-8 w/ Hankook Z214, Apex ARC-8 w/ BFGoodrich R1, MCS 3-way Coilovers, GC Race Camber Plates, PFC BBK, Turner Camber Arms, Turner Sway Bars, Turner Subframe bushings, Turner Solid Diff Bushings, Turner Solid RTAB, Turner Solid Control Arm bushings, Treehouse Racing FCAB, Reinforced Subframe, OS Giken LSD, Rogue Engineering Transmission Mounts, SGT Headers, SGT Section 1, AFE Stage 2 Intake, EPIC Tune, Dinan Exhaust, Bimmerworld Airdam/Splitter/Dive Planes, Bimmerworld V2 Wing, TC Design Roll Cage, Racetech RT4119, Scroth Profi 2 Harness
NORCAL Rod Bearing/Vanos/Valve Adjustment/Inspections Member Feedback
Jump to top DanAvoN7 is online now   Reply With Quote
Discussing Camshaft maintenance in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
