Old Tue, Oct-15-2019, 07:52:33 AM   #11
Nfaj
Reputation: 0 Nfaj is on a distinguished road
Default Re: Clutch pedal vibration and grinding
Originally Posted by sapote View Post
I think the old TB started to seize up at high rpm and not the shift fork pivot pin which should not be any difference at high or low rpm.
Btw, if the fork touched the bellhousing there should be no noise because the bellhousing doesn't rotate. It must had touch the pressure plate.
i was thinking just that. I dont know why it would sieze at high rpm?
Jump to top Nfaj is offline   Reply With Quote
Old Tue, Oct-15-2019, 07:14:18 PM   #12
sapote
Old dried bearing might act up at high speed. It is natural cause and effect.
Old Tue, Oct-15-2019, 07:16:22 PM   #13
sapote
When remove tranny and look at the pressure plate fingers where the TB rides on, if the fingers worn with a circular groove then it proves a seized TB.
Old Tue, Oct-15-2019, 08:12:50 PM   #14
Nfaj
Will I have to replace the pressure plate then?
Old Tue, Oct-15-2019, 08:39:48 PM   #15
sapote
depending on how deep the grooved fingers are. If half thickness then toss out, but if 1/4 then maybe ok to reuse.
Old Wed, Oct-16-2019, 01:14:46 AM   #16
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Originally Posted by iam_tylerbrown View Post
The brass pivot pin in my ladies m3 became flat, causing the clutch release fork to hit the bell housing when the clutch was fully pressed to the floor. It made a loud grinding sound. I experienced it more often on an uphill slant/slope. I could shift the car just fine without making it grind by not pressing the clutch all the way to the floor.
I’m not “for” or “against” the brass pivot pin. I replaced the brass one for an OE pivot pin. Both are fine in my opinion.
While our situations differ, it may be the same issue.
Attachment 217568
Did you install that pivot pin. Cause here’s the thing.
The brass ones don’t just slide right in. They are slightly bigger than the hole they’re made to go in. So we have three methods of...entry (that’s what she said) but only one will leave it looking intact. I bought two of these when I did my clutch job. Those doing one make sure you read this.
You can use a hammer to bang it into the hole. (That’s what she said) But this will flatten the entire nose of the pin and will actually shorten it by a considerable amount. I remember almost 2cm. Now to be honest I don’t think this will affect anything. However, when you think about how much time it took to get this trans out you really don’t wanna do this again.
The second method is to use the open part of a socket. 17mm I believe. The deep end. This doesn’t flatten the nose but you have a new issue. The little ring in the middle ends up getting smashed and you cannot fit the spring in! Once again I’d skip this.
And my preferred method was to use the BACK of a 3/8” socket. This will spread the force out along the nose and minimize smashing.
Photo below shows what happens from the hammer method.
And be sure to hit it straight on. It will bend very easily.
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Old Wed, Oct-16-2019, 01:17:14 AM   #17
Whitehawk8
Whitehawk8's Avatar
Default Clutch pedal vibration and grinding
If you’re using a stock pressure plate then yes you will. The pressure plate is self adjusting so unless you have the $1000 reset tool just buy the new pressure plate for 300 with the clutch.
and the list that monkey made earlier is perfect. This is the ultimate “while you’re in there” job lol
Old Wed, Oct-16-2019, 01:26:54 AM   #18
foolio
40oz. to Freedom
Reputation: 0 foolio is on a distinguished road
On an e46 non-M I had the slave cylinder shaft where through the clutch fork. When you depressed the clutch all the way it would contact the pressure plate making a horrible sound. Nothing to do with rpm though. Now I know why they recommend you replace those when you do a clutch job.
______________________________________________
1981 BMW 320is - 5MT - Polaris/Black
2001 BMW 325xiT - 5MT - TiAg/Grey Leather - ZPP, ZSP, ZCW, NAV, PDC
2002 BMW M3 - SMG - TiAg/Black Leather - KWV3
2003 BMW M3 - SMG - Laguna Seca Blue - Track car, track stuff
Jump to top foolio is offline   Reply With Quote
Old Sat, Oct-19-2019, 04:51:27 AM   #19
mrgizmo04
mrgizmo04's Avatar
I used a file and ground down the end that goes into the bellhousing. Just in case that thing has to come back out again at some point, if you force it in there you will have a hellavatime getting it out.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Oct-19-2019, 04:56:41 AM   #20
mrgizmo04
mrgizmo04's Avatar
The SAC reset can be done with a 3 jaw puller and a screw driver, if the pp is in good shape still. There are some threads on the forum and few youtube videos on how to do it. It is pretty simple and the tool (which I believe ECS sells) is not needed. Other route is to borrow the tool, but I don't think I've seen anyone in the rental thread advertise it.
'05 M3 6MT coupe
Discussing Clutch pedal vibration and grinding in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
