Old Sun, Oct-13-2019, 05:19:41 AM   #1
335dye
Reputation: 0 335dye is on a distinguished road
Default Left Side Higher than Right
I recently installed a set of 19 csl rep wheels and tires on my coupe. I originally had stock staggered 18s on stock suspension. I added 19x8.5 ET35 and 19x10 ET30 wheels on 225/40/19 and 255/35/19 tires on stock suspension. I have noticed that the left side is higher than the right. When using the trusty finger measurement, i can get two fingers high on the passenger side and three on the driver side. Everything I have seen has said that this is common and has to do with compensating for the weight of the driver. I do not recall it being so noticeable on the stocks 18s. Is there something that may have gone wrong or i may be missing? I also noticed that there is maybe a finger worth of space between the tire and bottom of the spring seat on the passenger side and more on the driver side. Should I be concerned? I plan on putting the stick wheels back on to see if it goes back to normal. Could the issue be the new wheel sizes? Thanks
Jump to top 335dye is offline   Reply With Quote
Old Sun, Oct-13-2019, 05:35:07 AM   #2
lmtfi
lmtfi's Avatar
Default Re: Left Side Higher than Right
Check tire pressures, put a driver in and re-measure to center caps.
Old Sun, Oct-13-2019, 05:43:05 AM   #3
Paulo M
Probably an illusion. It’s more noticeable now Bcs you see more rim than tire. Now you’re looking at it more than when you weren’t concerned about it.
BREMBO APEX DIXIS
Old Mon, Oct-14-2019, 02:56:58 PM   #4
legacyej25
Reputation: 0 legacyej25 is on a distinguished road
Suspension might need to settle a little if it spent some time in the air, especially if one side was in the air longer than the other.
2002 Carbon Black on Cinnamon
Jump to top legacyej25 is offline   Reply With Quote
Old Mon, Oct-14-2019, 03:30:15 PM   #5
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
OP are you running coilovers? Do you have control arm/spring perch reinforcement plates?
JaredMV's M3 Touring Build: http://www.m3forum.net/m3forum/showthread.php?t=604213
Originally Posted by Jaredomin View Post
8k shipped. Lmk thanks
Discussing Left Side Higher than Right in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
