Old Sun, Oct-13-2019, 03:41:01 AM   #1
rja4z3
Reputation: 0 rja4z3 is on a distinguished road
Default Front Clunk when braking, accelerating and turning
Hi all, trying to diagnose a clunk that happens pretty much during any transition the car makes. A shop took a quick look and thinks it's the steering rack, but when I jacked the car up, there is no leaking and no play in the wheels when I try to shake them. With the front in the air, neither wheel has play and quickly wiggling the swing arm links, tie rods, etc didn't show play either. Thoughts?
The car is a 2003 with 103k miles. Service 1 and 2 are done. Anyone have ideas. I need to take the skid plates off and check for loose bolts I guess. Any feedback is appreciated!
Jump to top rja4z3 is offline   Reply With Quote
Old Sun, Oct-13-2019, 03:43:03 AM   #2
11b4
11b4's Avatar
Default Re: Front Clunk when braking, accelerating and turning
Are you able to point out where it's coming from when you brake? Like front left or right? Is it like a metal on metal clunk or something light/heavy clunking
Sent from my Pixel 3 XL using Tapatalk
Old Sun, Oct-13-2019, 03:44:58 AM   #3
lmtfi
lmtfi's Avatar
Did they look at bushings and the shock towers?
Old Sun, Oct-13-2019, 07:34:45 AM   #4
liam821
Reputation: 0 liam821 is on a distinguished road
Swaybar bushings?
e93 M3 Melbourne Red on Black Novillo leather
e46 M3 Phoenix Yellow on Imola Red
e46 M3 ZCP Interlagos Blue on Imola Red in many many many pieces...
e73 xDrive35d Platinum Gray Metallic on Cinnamon
Jump to top liam821 is offline   Reply With Quote
Old Sun, Oct-13-2019, 02:09:11 PM   #5
ThunderMoose
Muffler bearing?
Old Mon, Oct-14-2019, 04:06:51 PM   #6
Treflip
Treflip's Avatar
Reputation: 0 Treflip is on a distinguished road
I'd start with checking your FCABs. When they blow out you'll feel clunks up front when coming to a stop and accelerating. Attached was my original FCAB that's completely torn apart.
Instagram: @tonyjackson | 2002 E46 M3 Build Thread | YouTube - Track Videos
Eibach | Yokohama | Ground Control | VAC | Evasive | Stillen-AP Racing | AFE | Koyo | TTFS | MOMO
Jump to top Treflip is offline   Reply With Quote
Discussing Front Clunk when braking, accelerating and turning in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
