Old Sat, Oct-12-2019, 04:43:00 AM   #1
Jake.s54
Reputation: 0 Jake.s54 is on a distinguished road
Default Evolve Airbox, Going into Limp mode
Hey guys i just installed my used evolve airbox then i bought from a friend, and since it was his before the tune is vin locked to him, so i am going to have to get a tune. Anyways i installed everything and he said it would be alright if i gave it a spin just to hear it because why not and i went for a little drive and finally was able to floor it and the car went into limp mode, It had EML/traction light and yellow brake light. I have seen a video of someone driving their car without the tune and he was ripping it and it was all fine. I got a code for the MAF and thats it. I am confused why this is happening and if i need a tune to drive it, i am planning on getting a tune, i am just confused why i cant floor it without a tune. Let me add also that the car idles perfect and drives normally perfect, its just at WOT(full throttle) it gives out into limp mode
Jump to top Jake.s54 is online now   Reply With Quote
Old Sat, Oct-12-2019, 07:40:15 AM   #2
HassanEido
HassanEido's Avatar
Lebanon
Default Re: Evolve Airbox, Going into Limp mode
holy orange font batman, I had to copy your text into notepad to be able to read anything
of course you need a tune to drive it...You can't just install an airbox and just drive with no tune..
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Sat, Oct-12-2019, 10:30:51 AM   #3
ksa74f
ksa74f's Avatar
Reputation: 0 ksa74f is on a distinguished road
Scotland
Check the throttle bodies and linkage aren't catching on any clamps etc
Cheers Kev
Jump to top ksa74f is offline   Reply With Quote
Old Sat, Oct-12-2019, 11:48:23 AM   #4
ThunderMoose
100% this
Old Sat, Oct-12-2019, 01:14:08 PM   #5
HassanEido
HassanEido's Avatar
Lebanon
Come to think of it, it's more than likely this is the case too. Probably one of the clamps is catching on throttle body linkage
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Sat, Oct-12-2019, 01:35:37 PM   #6
Altaran
Reputation: 0 Altaran is on a distinguished road
Germany
No tune means that it will go into limp mode. Evolve uses the MAF wiring to connect to the temp sensor. That won't work without the needed programming...
Gesendet von meinem LON-L29 mit Tapatalk
Jump to top Altaran is offline   Reply With Quote
Old Sun, Oct-13-2019, 01:03:11 AM   #7
Jake.s54
Originally Posted by ThunderMoose View Post
100% this
Figured it out thanks to you guys, checked my hose clamps and it was right in front of the throttle actuator arm and at full throttle would hit it, I would have never thought of this without you guys, i really appreciate it. Jake
Old Sun, Oct-13-2019, 02:48:16 PM   #8
ksa74f
ksa74f's Avatar
Scotland
Nice easy fix mate.
Cheers Kev
Old Mon, Oct-14-2019, 05:52:32 PM   #9
///MonkeyTech
Reputation: 0 ///MonkeyTech is on a distinguished road
A lot of people change out the factory clamps , I like the factory clamps because of the clearance, and I also have the correct tool to remove and install them. The only time i would change the clamps is if the engine is boosted IMO
Jump to top ///MonkeyTech is offline   Reply With Quote
Discussing Evolve Airbox, Going into Limp mode in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
