Old Sat, Sep-21-2019, 12:27:47 AM   #1
ac427
Reputation: 0 ac427 is on a distinguished road
United Kingdom
Default Gearstick linkage yellow washers
Are the yellow washers on the gearstick linkage made from a tough material like Delrin?
They don't seem to last long. Has anyone replaced them with a tougher material or just put metal washers on instead?
Jump to top ac427 is offline   Reply With Quote
Old Sat, Sep-21-2019, 07:35:47 PM   #2
Andrebxp
Reputation: 0 Andrebxp is on a distinguished road
Default Re: Gearstick linkage yellow washers
AFAIK, BMW revised the shifters and the selector rod joints to be used without those yellow washers.
Jump to top Andrebxp is offline   Reply With Quote
Old Wed, Oct-16-2019, 03:41:09 PM   #3
ac427
United Kingdom
Was this a modification to the E46 M3 gearstick or a change in the parts conned to it?
Old Wed, Oct-16-2019, 05:41:20 PM   #4
ClutchKickChris
Reputation: 0 ClutchKickChris is on a distinguished road
It's a update to the selector rod joint:
https://www.fcpeuro.com/products/bmw...nt-25111222688
Jump to top ClutchKickChris is offline   Reply With Quote
Old Wed, Oct-16-2019, 05:47:00 PM   #5
Andrebxp
The gear lever was updated as well.
Old Wed, Oct-16-2019, 08:22:48 PM   #6
I've never seen one worn out (too many to count). What exactly are you doing wrong to kill them?
Old Wed, Oct-16-2019, 08:26:08 PM   #7
^100% agreed
Old Thu, Oct-17-2019, 02:21:27 AM   #8
sapote
Don't see the new updated shift lever on realOEM. Anyone has the pic of the new and old levers for the difference?
Old Fri, Oct-18-2019, 09:38:36 AM   #9
ac427
United Kingdom
I just have a lot of gearstick slop that I would like to cure.
When I heard there had been a revision to the linkage. I thought I would fit it but could find no information about the parts required.
Old Fri, Oct-18-2019, 07:24:22 PM   #10
Ok, but that isn't due to the yellow washers.
The majority of gear stick slop comes from the foam bushing in the selector rod joint disintegrating. You can change to the updated aluminum version. It will come with fresh foam and revised mounting that doesn't use the washers. The foam wears out ever ~5 years or so.
You should also replace the carrier bushings front/rear and the gear lever can be shimmed to take the slop out of the rubber isolator.
Selector Rod Joint - Alu version
https://www.ecstuning.com/b-genuine-...t/25117580281/
Front Carrier Bushings - Aftermarket Delrin
https://www.rogueengineering.com/Rog...ings_p_69.html
Rear Carrier Bushing - Aftermarket Poly
https://www.ecstuning.com/b-turner-m...021012tms02~a/
OEM M Performance Shift Lever
https://www.ecstuning.com/b-genuine-...r/25117527259/
The foam in the selector rod joint I'm talking about (25111434194);
Discussing Gearstick linkage yellow washers in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
