Old Wed, Sep-25-2019, 09:05:50 PM   #41
11b4
11b4's Avatar
Default Re: M3 Craigslist to buy or not to buy
Check all the fluids. Brakes, cooling, trans, diff. If it's on the original water pump is be a little skeptic on the rest. Might of been "pampered" but I would do it for peace of mind.
Sent from my Pixel 3 XL using Tapatalk
Old Wed, Sep-25-2019, 09:18:13 PM   #42
alexM3Chicago
Reputation: 0 alexM3Chicago is on a distinguished road
Dude. You stole that car at $5,900.
Do the rod bearings yourself, overhaul the cooling system, get new lenses for the headlights, rewrap the steering wheel, and pop some LED tails on it and youíll have a decent little daily driver.
2002 BMW M3 - Laguna Seca Blue - Black - 6 Speed Manual
Build Journal: http://www.m3forum.net/m3forum/showthread.php?t=564786
Jump to top alexM3Chicago is online now   Reply With Quote
Old Wed, Sep-25-2019, 09:56:12 PM   #43
Bmwpower603
If I can figure out which bolts Iím going to use, maybe Iíll do the RBs. BMW says to re use the bolts that are in there already.
Or should I chance distortion with ARP bolts?
Old Wed, Sep-25-2019, 09:59:37 PM   #44
11b4
11b4's Avatar
You can reuse them on the preface lift. If you want. If I were you and plan on doing the rod bearings. I'd buy a timing chain sprocket. They are made out of plastic and wear out over time.
Old Wed, Sep-25-2019, 10:47:10 PM   #45
Bmwpower603
I did not know about the sprocket. Thank you for the suggestion.
As far as the bolts go. The shop who did my e90 RBs. Said they prefer to use ARP bolts, opposed to re using stock bolts.
But the ARP bolts will cause distortion? Or is that a myth?
Old Wed, Sep-25-2019, 10:58:24 PM   #46
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
I think he meant the upper timing chain guide, not sprocket, is made out of plastic. Beisan sells an improved one.
I think ARP bolts are good but the shop will need to install them correctly.
Since yours was a recalled car, you might have the newer rods in there.
Almost feels like you need to have both on hand once you drop the oil pan to see what you've got in there.
2003 M3 IR/black - "bought with 195k miles pre-installed"
Beisan - WPC rod bearings - K&N FIPK - JRZ RS One 450F/550R - GC Race camber/caster plates - Z3 steering rack - Volk Racing G2 18x9.5 square - Turner camber arms - Redish RACP plates - SyncroDesignWorks RTAB - Bride Euroster II (black gradation) - OE LED taillights
ig: @zzyzx85
Jump to top Zzyzx85 is online now   Reply With Quote
Old Wed, Sep-25-2019, 11:05:40 PM   #47
11b4
11b4's Avatar
Nope. Sure didn't. The upper timing chain gets worn out as well, but I ment oil pump sprocket. https://www.ecstuning.com/b-genuine-...t/11411317284/
Side note. I heard there's another new solution to the upper chain guide. Apparently there's a billet aluminum one out there?
Old Wed, Sep-25-2019, 11:18:52 PM   #48
Zzyzx85
Zzyzx85's Avatar
Interesting. Never read/heard of that part having issues though, but as with most German plastic parts, it's gotta be a wear item, right?
TIL.
ig: @zzyzx85
Old Wed, Sep-25-2019, 11:19:57 PM   #49
Bmwpower603
BMW didnít install new rods. The service advisory was strictly the bearings only.
I will have to call and double check. But new rods would require engine tear down, and crank removal. BMW doesnít do that.
Old Thu, Sep-26-2019, 02:36:08 AM   #50
HDdave
HDdave's Avatar
Reputation: 0 HDdave is on a distinguished road
Originally Posted by Paulo M View Post
You buy $7k m3’s just for the fun of it. Looking forward to building it etc. If you’re already this concerned about its condition, then you’re obviously looking for something more than a $7k m3.
Paid $7k on the dot for mine.. This was my exact intention and this is very true. I probably have put another $8-9k in it too and only knocked out one of the big 3.. Which yes I know is stupid...
But I will be 100% honest... I see s54’s all the time for like $3k or so. More or less I hope I get to them before they let go (I was replaced under warranty at 18k according to records, and I have 153k).. But if not, well its not like trying to find an s65. They can be a little pricey.
Looks like you stole the car man! Especially for it being 6 speed already- I had to convert mine. Congrats!
Also- it seems like we are in the same boat rod bearing wise. I have no idea what to expect when I drop my pan. I am like 3/2003 build date. Kinda also feel like I need both sets on hand when I do get to it..
2003 TiAg 6mt- VMR 710ís, PS4s, Dynavin, Bavsounds, Coby Wheel, AFE, Angel Eye Guy, VAC, Mishimoto
16 Denali HD Duramax Stone Blue Metallic- Toyo 35's
Jump to top HDdave is offline   Reply With Quote
Discussing M3 Craigslist to buy or not to buy in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
