Old Fri, Aug-16-2019, 07:03:57 PM   #11
scaley
scaley's Avatar
Reputation: 0 scaley is on a distinguished road
Default Re: PSA: check your front diff bolt
Originally Posted by antknee View Post
I reversed the car onto my raceramps. Supported the diff w/ my jack. Removed the 8mm nut from the center of the plastic belly pan (there was a piece of plastic protruding up, getting in the way a bit if you don't remove this nut). From there I took a 13/16 socket w/ long extension, and was able to tighten the front diff bolt from doing just that.
I will try it again and report back, but I remember the brace which covers both front subframe bushings being right in the way of giving me a straight angle onto the bolt. I remember thinking how it'd be impossible to fully tighten that front diff bolt without dropping the entire subframe and then tightening it. Maybe I'm just dumb and completely missed something. I'll try it again.
Jump to top scaley is offline   Reply With Quote
Old Fri, Aug-16-2019, 07:08:58 PM   #12
scaley
scaley's Avatar
Originally Posted by mrgizmo04 View Post
It might not solve the "mclunk" because there could be a lot of other parts like halfshafts, actual diff backlash, diff clutches, driveshaft joints, etc making noise.
Separately, you should not need ujoints at all, there is a pretty open straight shot. You should not even need to remove the v brace. If you remove the v brace and the plastic cover on pass side, 21mm socket and an a small extension is all that is needed. Possibly that your the head of your torque wrench is large, but with the right extension length you can fit it in without removing anything else.
I'm hoping it solves my M-clunk because it's the easiest and cheapest option lol. I'm planning on upgrading to a 4.10 Diffsonline diff in the future but until I save up enough for it I would love to fix my clunking stock diff. I have already replaced every bushing in the rear end when I reinforced the floor along with my CSB so I know it's none of that causing the issue. I will try tightening the bolt again and see if I have better luck.
Old Fri, Aug-16-2019, 07:55:50 PM   #13
mrgizmo04
mrgizmo04's Avatar
By design, the diff on m3 will clunk - clutch design of lsd unit, different length between output shafts on driver vs passenger side and to extent the backlash.
I have Dan's 4.10 unit and it did not solve any clunking.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Aug-16-2019, 08:19:46 PM   #14
scaley
scaley's Avatar
Did you keep the viscous LSD setup and just have him replace the R&P? I am planning on having him replace mine with a 2 clutch or 3 clutch setup to get away altogether from the clunking of the factory diff setup.
Old Fri, Aug-16-2019, 10:43:34 PM   #15
mrgizmo04
mrgizmo04's Avatar
Yes, I kept the factory LSD unit.
'05 M3 6MT coupe
Old Fri, Aug-16-2019, 11:03:42 PM   #16
WoGGo
Reputation: 0 WoGGo is on a distinguished road
Front diff bolt part number?
Jump to top WoGGo is offline   Reply With Quote
Old Fri, Aug-16-2019, 11:54:45 PM   #17
nujav
nujav's Avatar
Reputation: 0 nujav is on a distinguished road
How did you guys even remove the rear bolts? I don't have enough clearance to take mine out because that spare tire hump is in the way.
Jump to top nujav is offline   Reply With Quote
Old Sat, Aug-17-2019, 12:59:41 AM   #18
iam_tylerbrown
iam_tylerbrown's Avatar
Reputation: 0 iam_tylerbrown is on a distinguished road
The e46 m3 doesn’t have a spare tire.
Jump to top iam_tylerbrown is offline   Reply With Quote
Old Sat, Aug-17-2019, 01:01:10 AM   #19
mrgizmo04
mrgizmo04's Avatar
Socket/ratchet with a swivel to break it loose, then open end wrench and some patience. I swapped my diff cover/bushings recently, not too bad.
'05 M3 6MT coupe
Old Sat, Aug-17-2019, 01:03:39 AM   #20
mrgizmo04
mrgizmo04's Avatar
33177840535 about $20
'05 M3 6MT coupe
Discussing PSA: check your front diff bolt in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
