Old Sat, Jul-28-2018, 07:25:57 PM   #1
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Default DIY Wrenchers Unite
Letís talk about macgyver tricks and best practices that make garage life easier. Iíve thought about this during some different projects and would like to see what kind of garage creativity is out there.
E46 M3 Toolkit - in progress
6,8,10,11-19mm shallow sockets 3/8Ē
8,10,13mm deep sockets 3/8Ē
17mm hazel wheel lug .5Ē
3/8 ratchet
.5Ē ratchet
5,Allen sockets
T25,30,35,40,50 sockets
As of right now Iím gonna say having my tools on a roller has been awesome. Iím gonna buy a $15 harbor freight dolly to get this lower and more Permanent.
Iím huge on safety because it allows me to take more risks. I get my car on jack stands and use my tires at all four corners of the frame rail. Additionally I use my winter tires under my subframes double stacked.
Jump to top Blaikenstein is offline   Reply With Quote
Old Sat, Jul-28-2018, 07:43:55 PM   #2
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Cool thread. I would have to say my Hockey Puck Jack Pads. They work great and less likely to slip beings they are hard rubber material. And it only cost $10.
Old Sat, Jul-28-2018, 07:51:01 PM   #3
Default Re: DIY Wrenchers Unite
Here are most of my "special" tools. Some of them are very simple but are so useful like a small flat head screwdriver - can't tell you how often I use it. Forgot to put out the power steering line disconnect tool as someone else later mentions. I also have a second jack, a scissor jack, that is very helpful for raising the wheel hubs when doing suspension/brake work. Also not pictured are C-clamps I use to push caliper pistons back in. There's a drag link socket that I ground down to fit the CPV, there's a set of 10mm-18mm wrenches that I ground down to 3/16" thick which are great for places like swaybar endlinks! Sparkplug and O2 sensor sockets are perfect for our front struts (If you don't have impact drill) so you can both turn the nut and hold the shaft.
I also always have extra clips, push rivets, screws, nuts, washers all BMW specific that I or someone else always seems to need once you get in there!
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" SS unres dual pipe 2.5" sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/shroud/SAP/washer/fog deletes CSL battery
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack
Old Sat, Jul-28-2018, 07:56:30 PM   #4
bigjae1976
Canít believe you wasted a perfectly good hockey puck! Lol
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sat, Jul-28-2018, 08:02:22 PM   #5
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Yep killed them suckers!
Old Sat, Jul-28-2018, 11:19:07 PM   #6
HassanEido
HassanEido's Avatar
Lebanon
Great thread!
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Sat, Jul-28-2018, 11:44:04 PM   #7
propchef
Toodle-oo Motherf**kers
propchef's Avatar
Reputation: 0 propchef is on a distinguished road
As long as you promise not to call them "hacks."
Park bicycle tools make a number of great slim wrenches that can get into places ordinary wrenches can't, such as sway bar end links.
Lego tools are indestructible and plastic so they're good for trim removal (think roundel replacement).
Originally Posted by AllwaysLow View Post
x2 and some Chicago style pizza
Originally Posted by M3Dom View Post
He's suffered enough.
Originally Posted by EKaru View Post
STFU Klong!!!!! Go Fuk Yourself!
Jump to top propchef is offline   Reply With Quote
Old Sat, Jul-28-2018, 11:53:25 PM   #8
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Lol...Like these?
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, Catcam's Billet 280/272 cams, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
For Sale: BNIB OE CSL Wheels
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Old Sat, Jul-28-2018, 11:59:25 PM   #9
propchef
propchef's Avatar
Old Sun, Jul-29-2018, 12:00:50 AM   #10
Blaikenstein
When I cross threaded my timing chain tensioner I ended up ďmachiningĒ a m26-1.5 bolt with a few files, a micrometer and a hand drill.
I micíd my chain tensioner and used the bolt in a regular drill on the file to get it close. For the last bit I used a thread file to get the threads nice and deep.
I cleaned the threads by inverse threading the bolt a bunch of times. Iím really proud of this one and would definitely lend it out if anyone needs it.
Discussing DIY Wrenchers Unite in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
