Old Tue, Oct-15-2019, 06:31:58 PM   #61
brandroidian
Reputation: 0 brandroidian is on a distinguished road
Default Re: Throttle position problems, codes P0121 and P1637, new throttle actuator + sensor
Originally Posted by carson432 View Post
Be sure that the throttle actuator rod is not hitting anything and rotates with no obstructions. I installed new intake clamps and the bolts on the rod would hit the screw heads on the clamps and through the car into limp mode .I rotated the clamps and problem was solved.
THANK YOU!!!!!!!!!!
I did a valve adjustment last week and changed my oil cooler lines. After putting it all back together I was getting P1637. Today I replaced both TPS and still when I would get on the pedal hard, it would go into limp mode. I was about to order the pedal sensor next, but decided to get on here and found this.
Last year I'd replaced the rings around the intake manifold boots with just standard flathead screw hose clamps for easier removal and installation in the future. Well, as you predicted, they weren't hitting the rod, but the levers that are on the shaft. This is why it was only happening when I would floor it, that was the only time the shaft was rotating around enough to hit my hose clamps
Jump to top brandroidian is offline   Reply With Quote
Discussing Throttle position problems, codes P0121 and P1637, new throttle actuator + sensors an in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
