Old Wed, Apr-11-2018, 03:26:42 AM   #21
Syfon
Reputation: 0 Syfon is on a distinguished road
Default Re: Throttle position problems, codes P0121 and P1637, new throttle actuator + sensor
Cleaned the MAF and top TPS a few nights ago. Car won't start at all now (WTH?!).
Just to recap, it has a brand new battery, brand new fuel pump and brand new bottom TPS. I am yet to test the sensor in the throttle pedal.
The thing is, now it won't start. It's cranking over, just not starting. Has fuel in the tank, can hear the fuel pump priming. Coil packs have maybe 10,000km (6,000miles) on them.
Here's the strange thing - last week, it started and drove fine for a bit until it threw the EML light (plus associated codes) again. Got the car home, continued looking at the possible issues of the TPS, throttle actuator, etc. Then last Sunday, started it, let it idle for a bit, then it began idling rough and died. Now it won't start at all.
Can anyone shed some light on this issue?
Is it related to the EML light & associated codes?
I'm completely stumped at the moment
Edit: Scanned for codes with both a hand-held scanner and laptop running BMWLogger; no codes at all.
Jump to top Syfon is offline   Reply With Quote
Old Wed, Apr-11-2018, 03:39:09 AM   #22
mrgizmo04
mrgizmo04's Avatar
Swap the throttle pedal with your friend to see what it does, but I'm not sure if that is the issue. Have to check air/fuel/spark related components. I don't think blown coils/spark plugs/injectors throw codes.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Apr-11-2018, 03:40:59 AM   #23
mrgizmo04
mrgizmo04's Avatar
Also, try unplugging the maf, to see if it starts and runs. These film mafs are tricky.
'05 M3 6MT coupe
Old Wed, Apr-11-2018, 03:52:20 AM   #24
CSLM3Wannabi
Check your fuel pressure. You may hear the pump priming or even running, but I have seen a hose pop off of a new pump assembly inside the unit and just circulate the fuel in the tank.
2005 BMW M3 ZCP Nardo Gray | ESS VT2-550 | Dinan Throttle Bodies | 6MT Swap | Active Autowerkes Headers + Section 1 w/ 100 cells | Miltek Section 2 and 3 | KW V2 w/ GC camber plates and Eibach Front and Rear Swaybars | Porsche 996 BBK upgrade w/ OEM ZCP rotors | Umnitza V4 Angel Eyes | Euro bumper w/ Morimoto led fogs | 1 piece Carbon Lip | VIS XTS Full carbon hood | SCZA Carbon Fiber CSL Trunk | Carbon Fiber CSL Diffuser | Square ZCP Wheels |
Old Wed, Apr-11-2018, 03:58:31 AM   #25
mrgizmo04
mrgizmo04's Avatar
Check fuse 54(?) for fuel pump in glove box
'05 M3 6MT coupe
Old Wed, Apr-11-2018, 04:00:50 AM   #26
Syfon
Tried this to no avail.
Thanks, I'll try this. I can easily pull the pump assembly out of the car to check; takes all of 2 minutes.
I'll also get under the car and check for pressure.
As far as I understand, the SMG & 6-speed manual throttle pedals are different and thus not interchangeable?
I'll test mine with a multimeter and see what voltage it produces.
As for the coils/spark, when I drove it last week, and when it was idling this past Sunday morning, it drove and idled smooth (i.e. no misfire).
Now, it simply won't start. It cranks and turns over, just not actually firing up.
Old Wed, Apr-11-2018, 05:30:32 AM   #27
Syfon
Have checked Fuse 54 - it's fine.
I'll also check the fuel pump relay tonight.
Old Wed, Apr-11-2018, 01:40:52 PM   #28
Syfon
Checked ALL the fuses and relays tonight; no issue.
Also scanned with INPA; no codes.
Thought it may be low on fuel (even though the fuel gauge showed 1/4), so I put 10 litres in and she still won't start.
I'm going to pull the fuel pump and check to make sure nothing is faulty there. Will also replace the fuel filter and check for fuel pressure while I'm there.
Will report back tomorrow evening...
Old Wed, Apr-11-2018, 04:05:01 PM   #29
CSLM3Wannabi
If you can hear the pump priming, that would indicate the fuse is and relay are good. You need to confirm you have fuel pressure.
You should also check for spark. If you dont have a tester, pull a coil out leaving it connected and put a spark plug in it while someone cranks the engine to confirm.
Old Thu, Apr-12-2018, 01:33:08 AM   #30
Syfon
Yes, can definitely hear the fuel pump priming.
Thanks for the advice. I'll be checking for fuel pressure & spark tonight.
Discussing Throttle position problems, codes P0121 and P1637, new throttle actuator + sensors an in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
