Old Fri, Apr-06-2018, 08:24:01 AM   #11
Syfon
Reputation: 0 Syfon is on a distinguished road
Default Re: Throttle position problems, codes P0121 and P1637, new throttle actuator + sensor
Originally Posted by FrankJones View Post
Make sure your new TPS are genuine BMW parts. Donít do anything aftermarket when it comes to electronics. That was my issue.
The new TPS I installed is a genuine part.
I'm going to swap my throttle pedal with a friend's early next week. Will report back and advise if this solves my issue.
Jump to top Syfon is offline   Reply With Quote
Old Fri, Apr-06-2018, 03:27:08 PM   #12
BladeM3
Reputation: 0 BladeM3 is on a distinguished road
I had the problem for 1 month.. i changed the actuator, the tps, the throttle pedal, check the DME and everything.. Problem solved when i've cleaned the connector of the TPS ... I've spent money, gasoline, time to test the car and it was something just so simple....
Jump to top BladeM3 is offline   Reply With Quote
Old Mon, Apr-09-2018, 04:50:08 AM   #13
Pbj24
Pbj24's Avatar
Reputation: 0 Pbj24 is on a distinguished road
I cleared the DME adaptations with BMW logger today. Took it for a drive. Drove fine for a bit but eventually I got the EML light. It did not go into limp mode though. Read the codes with BMW logger when I got home and this is what I got. I'm pretty stumped at the moment. I've gone through and sprayed down the front TPS connector and the maf connector with electrical contact cleaner. Cleaned the actual maf itself. I guess I could pull the intake and clean the connector to the TPS under there. I could also clean the connector to the pedal..
Jump to top Pbj24 is offline   Reply With Quote
Old Mon, Apr-09-2018, 02:45:21 PM   #14
CSLM3Wannabi
Are you able to view the voltage readings of the throttle pedal and throttle position sensors? If so, key on, engine off and slowly depress the throttle and watch the readings. If signals are missing, you may be looking at a loose connection (tighten terminals on connecter, dont just clean), high resistance in signal wire, or faulty DME. This is assuming the parts you have already replaced are fully functional. If there is a dead spot on either sensor readings, most likely a faulty sensor.
Old Mon, Apr-09-2018, 09:21:07 PM   #15
Pbj24
Pbj24's Avatar
How would I view the voltage readings?
Old Mon, Apr-09-2018, 09:48:33 PM   #16
CSLM3Wannabi
The easy way is with a scan tool that can view live data from the DME. The old school way is with a volt meter and back probing the sensors.
If you don't have access to a diagnostic scanner or do not know how to use a volt meter to measure a potentiometer I would suggest trying to tighten the terminals at each connector as a first step.
Otherwise you will need to link up with someone who can help you.
2005 BMW M3 ZCP Nardo Gray | ESS VT2-550 | Dinan Throttle Bodies | 6MT Swap | Active Autowerkes Headers + Section 1 w/ 100 cells | Miltek Section 2 and 3 | KW V2 w/ GC camber plates and Eibach Front and Rear Swaybars | Porsche 996 BBK upgrade w/ OEM ZCP rotors | Umnitza V4 Angel Eyes | Euro bumper w/ Morimoto led fogs | 1 piece Carbon Lip | VIS XTS Full carbon hood | SCZA Carbon Fiber CSL Trunk | Carbon Fiber CSL Diffuser | Square ZCP Wheels |
Old Mon, Apr-09-2018, 10:40:34 PM   #17
mrgizmo04
mrgizmo04's Avatar
I think bmwlogger (free to download on laptop) and a $10 OBD2->USB cable from Ebay or Amazon will do.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Apr-10-2018, 02:50:45 AM   #18
Pbj24
Pbj24's Avatar
I bought a cable from Amazon and downloaded BMW logger. I was able to read codes and clear dme adaptations but it was not letting me connect to view live data. It gives me a 'packet failure unable to connect to DME' error
Old Tue, Apr-10-2018, 04:02:54 AM   #19
CSLM3Wannabi
Unfortunately I cannot help you with your error. It sounds like an installation error or it is only a partial install to allow minimal diagnostics.
I use a number of diagnostic scanners including Snap-on Zeus, Autoland Scientech, and ISTA-D.
I am still teaching myself these other BMW "tools"
Old Tue, Apr-10-2018, 04:11:05 AM   #20
mrgizmo04
mrgizmo04's Avatar
Try reinstalling and car obviously has to be running to be able to connect.
'05 M3 6MT coupe
Discussing Throttle position problems, codes P0121 and P1637, new throttle actuator + sensors an in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
