Old Wed, Sep-25-2019, 03:07:38 PM   #1111
ZaXxon
Reputation: 0 ZaXxon is on a distinguished road
Default Initial Feedback on my experience
I purchased off Ebay for less than $250, and I couldn't be happier with them.
Build quality is excellent, and fitment was perfect. Bolted right up to stock US spec Section 1. I ended up re-using my stock hardware for the header to S1 flanges.
I'm running stock US spec sections and muffler and it sounds great. The perfect amount of rasp and deep growl. I was considering getting a catted S1, but not now after actually hearing it run.
Last edited by ZaXxon; Wed, Sep-25-2019 at 03:13:23 PM. Reason: Added a couple more pics
Jump to top ZaXxon is offline   Reply With Quote
Old Sun, Oct-13-2019, 05:25:34 PM   #1112
jtt777
jtt777's Avatar
Reputation: 0 jtt777 is on a distinguished road
Default Re: Megan Racing Headers
So anyone experience an intermittent exhaust leak on these headers only after the car is warmed up and only with the car is certain loads (like braking). I have noises that might actually be an exhaust leak and I am wondering if it the headers here. I did use OE gaskets on the install. I had a leak from the EGT but then fixed that. This noise is the only one i hear now.
2004 PY BMW M3
Jump to top jtt777 is offline   Reply With Quote
Old Fri, Oct-25-2019, 02:40:10 AM   #1113
jtt777
jtt777's Avatar
anyone else have this issue?
2004 PY BMW M3
Old Fri, Oct-25-2019, 03:03:11 AM   #1114
Drewster
Drewster's Avatar
Nope - used OE everything, and I've had issues keeping the EGT wires from melting with their odd bung placement, but no leaks
Old Fri, Oct-25-2019, 02:09:43 PM   #1115
royalflushness
royalflushness's Avatar
Reputation: 0 royalflushness is on a distinguished road
I'm so conflicted between Megan Headers and CPI Stepped...
Jump to top royalflushness is offline   Reply With Quote
Old Fri, Oct-25-2019, 04:02:43 PM   #1116
I'll help you...
Neither. Euro or SSv1.
Old Fri, Oct-25-2019, 09:31:43 PM   #1117
breadvan
I'll help you...
Exactamundo
Old Tue, Jan-21-2020, 05:41:03 AM   #1118
freshprince2421
freshprince2421's Avatar
Reputation: 0 freshprince2421 is on a distinguished road
Are these no longer available? Seems crazy.
Jump to top freshprince2421 is offline   Reply With Quote
Old Tue, Jan-21-2020, 05:51:28 AM   #1119
Here you go:
https://www.ebay.com/itm/BMW-M3-E46-...YAAOSwFMdal~zk
Discussing Megan Racing Headers in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
