Old Thu, Sep-19-2019, 06:43:30 PM   #561
RedOctober330
RedOctober330's Avatar
Reputation: 0 RedOctober330 is on a distinguished road
Default Re: e46 M3 Tire Sizing Thread
Track set is a set of OEM 18 rear squares with 265/40/18. SLIGHT rubbing on full turn but otherwise very sticky. And wide as hell.
Jump to top RedOctober330 is online now   Reply With Quote
Old Thu, Sep-19-2019, 11:45:00 PM   #562
mrgizmo04
mrgizmo04's Avatar
You run 40 profile instead of 35?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Sep-20-2019, 03:19:52 PM   #563
Quicky
Reputation: 0 Quicky is on a distinguished road
19x10.5 et 25 on 285/30/19 Nankang NS20 no rub so far. Koni shocks and I believe stock springs. No mods to fender. No spacers.
Jump to top Quicky is offline   Reply With Quote
Old Tue, Oct-01-2019, 10:03:42 PM   #564
CrisSilberGrau
Reputation: 0 CrisSilberGrau is on a distinguished road
Also looking to up my tire size from stock 225/255 on ZCP 19s.
Car is an 06 SB ZCP, I plan to run about 10 or so autocross events next year, maybe 1 or 2 track events, but those are a long maybe. Other than that, car will be for street driving and weekend carving weather permitting. Being a Toronto car I dont plan on winter driving.
I was thinking on going with the Ventus V12 EVO2 at 235-245/35/19 and 265/30/19.
Has anyone got any experience with these, it would be greatly appreciated.
Jump to top CrisSilberGrau is offline   Reply With Quote
Old Tue, Nov-05-2019, 02:36:55 PM   #565
delta3
Reputation: 0 delta3 is on a distinguished road
hi all, will 265/35/18 with 9.5J ET22 front and 275/35/18 with 10J ET25 rear on ohlins R&T rub (either body or springs)? no other mods, just camber dialed to whatever stock allows. thanks in adv!
Jump to top delta3 is offline   Reply With Quote
Old Tue, Nov-05-2019, 05:47:14 PM   #566
mrgizmo04
mrgizmo04's Avatar
Front should not rub on Ohlins, I run 265 on 9.5 et35 with 3mm spacer, you might rub on fender.
Rear I think there should also be plenty of room.
'05 M3 6MT coupe
e46, sizing, thread, tire
Discussing e46 M3 Tire Sizing Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
