Old Sun, Mar-01-2009, 02:21:11 AM   #1
chemworldx
Reputation: 0 chemworldx is on a distinguished road
Default Front tire rubbing lower spring pad
Hey everybody-
Today I changed my oil, transmission fluid, and did a CDV delete on my '03 M3 Coupe (72k miles). The car rode fine beforehand, and is sitting on stock 18" wheels and tires. I jacked the car up twice in the process, and removed the wheels for cleaning.
After I lowered the car the last time, the passenger front tire is rubbing against the lower spring pad.
Ride height seems within spec on the passenger side (24"), but slightly high on the driver's side (24 5/8"). It seems like the problem may have gotten worse (rubbing sound harder; I drove the car 30 miles before garaging it again (didn't recognize what problem was at first.)
It seems like the lower spring pad may be rotated on the passenger side, but I'm not sure how this would happen or how to fix it.
If anyone would like; I can e-mail you pictures of the driver and passenger side suspension.
Does anyone have any ideas on what is wrong or how to fix the problem?
Thanks,
Mark
Jump to top chemworldx is offline   Reply With Quote
front, lower, pad, rubbing, spring, tire
PSS9 VS Lower Spring which one no noise? garychen0919 E46 M3 (2001-2006) 1 Thu, Oct-30-2008 07:07:08 PM
Spring Pads - Replace to go Lower? GJGM3 E46 M3 (2001-2006) 11 Sun, Mar-02-2008 04:01:25 AM
How much can I lower without rubbing with Le37 10.5 rears w/25mm offset? SMG78 E46 M3 (2001-2006) 0 Sun, Feb-04-2007 05:23:30 PM
lux pkg and rear spring pad ///sleeper E36 M3 (1992-1999) 1 Sun, Mar-19-2006 02:35:18 AM
Anyone have problems w/ front tires rubbing spring perch? ziggy723 E46 M3 (2001-2006) 2 Sat, Aug-20-2005 09:31:08 PM
Discussing Front tire rubbing lower spring pad in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
