Old Thu, Jan-17-2019, 01:02:00 AM   #1
M3 dude
Default simple lightweight sec 3.
hi all,
i'm looking to save abit of weight and make some space under the rear of my m3.
i'm not worried about appearance (having the quad tips) but some sound attenuation is good. main motivator is shedding around 20kg (40lb) from behind the rear axle.
so, i'm looking to adapt something like a borla #400287 universal muffler to the outlet of the sec 2 - then route the pipes straight out the back.
anyone done something similar? any feedback on drone? or any other feasibility issues?
thanks
Old Thu, Jan-17-2019, 01:11:02 AM   #2
AussieE46M3
Reputation: 0 AussieE46M3 is on a distinguished road
Default Re: simple lightweight sec 3.
Side pipes? M3 GTR style?
I'd imagine that will take out some tubing.
For to ADR compliant you'd have to make the rear windows permanently shut and have it out just in front of the rear wheel on the RHS.
Jump to top AussieE46M3 is offline   Reply With Quote
Old Thu, Jan-17-2019, 01:29:43 AM   #3
M3 dude
not even, still have it firing out the back.
but the exhaust will have a straighter path than most a/market exhausts.
so yeh, less tubing, less bends, keep it simple, cheap, light.
edit: side pipes would be cool.
Old Thu, Jan-17-2019, 02:15:05 AM   #4
mrgizmo04
mrgizmo04's Avatar
That sounds like it'll be loud!
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Jan-17-2019, 02:16:19 AM   #5
Why's that, did you remove 40lbs from the front already? Or is this for drifting or something?
There are people that run just straight pipes. Or people that run a single canister, like for a single 3.5" track high hp exhaust.
The stocker is big and heavy on purpose though, which you moght have read about. Do you want LOUD?
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Thu, Jan-17-2019, 02:37:40 AM   #6
STAATS
STAATS's Avatar
unfortunately you can't really strip much weight back there and maintain ADR compliance in terms of noise... I am already struggling to see how I will pass noise with SS V2 Headers, SS Metcallic Cats, SS Resonated X-pipe and SS Sport Muffler...
SS Street box strips a few pounds and would maintain ADR compliance... other than that the best way to strip exhaust weight and maintain noise compliance is really to keep the stock back box but go to SS Metallic Cats (saves a few kgs) and SS Resonated X-pipe will save a few kgs also... there is a few pounds again to be saved on the SS Sport box over a SS Street but its still borderline if it will pass... I am getting access to a noise meter next week and will be testing my setup so will feedback if it is ADR compliant... I guess if you are ignoring Mod approval then providing its within a few dB's of ADR compliance then it won't be enough to trigger cops to yellow sticker you anyway so won't be an issue, but for me I am in the midst of Engineering Approval process so I am stuck with having to comply *sigh* haha.
STAATS
Old Thu, Jan-17-2019, 02:42:05 AM   #7
STAATS
STAATS's Avatar
alternatively... if the rest of your exhaust system is stock then SS lightweight race box on an otherwise stock exhaust I believe just passes noise test... I know Rajvosa had a SS LWR box on his E46 M3 approved once upon a time...
STAATS
Old Thu, Jan-17-2019, 03:56:19 AM   #8
Rajvosa
Reputation: 0 Rajvosa is on a distinguished road
Hi mate nah wasnít on the SS lightweight race. It was either street or sport version. After I sold all those I got LWR on
Jump to top Rajvosa is offline   Reply With Quote
Old Thu, Jan-17-2019, 04:56:29 AM   #9
STAATS
STAATS's Avatar
Ahhhh must have been the Sport then... Street is quieter than stock on a stock system I believe so no cop would have pulled you on that...
Do you remember what dB reading and at what rpm etc you got when you had to do that? (and was the system stock other than the back box?)
STAATS
Old Thu, Jan-17-2019, 06:45:31 AM   #10
Rajvosa
Man couldnít tell ya what numbers I got. I had V2 headers, resonated x pipe and whatever muffler it was. I only had it engineered cos I was getting brakes engineered so was a convenience thing. Didnít get pulled over about it
Discussing simple lightweight sec 3. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
