Old Tue, May-02-2017, 05:56:37 AM   #1
moreisbetter
Reputation: 0 moreisbetter is on a distinguished road
Default Help me find what this noise is
This developed today under normal freeway driving. Hoping for the best but prepared for the worse. 2004 SMG. Drives and sound normal till 0-5mph. When stationary, goes away with gas and goes away in between nuetral and 1st gear shifts. Oil levels are normal. One thing that i noticed is that my down shift paddle has recently stopped working intermittently and now it doesnt seem to respond anymore(not sure when it decided to give up all together). Replaced salmon relay with backup an no changes
Bay Area
Jump to top moreisbetter is offline   Reply With Quote
Old Tue, May-02-2017, 06:08:12 AM   #2
rovert604
rovert604's Avatar
Default Re: Help me find what this noise is
Does it jack hammer when you first hit unlock or open a door without any ignition? Or can you hear the pump prime as normal?
--Trevor in 604--
Vancouver, BC, Canada
Old Tue, May-02-2017, 06:13:28 AM   #3
moreisbetter
It primes like normal
Bay Area
Old Thu, May-04-2017, 11:16:08 PM   #4
moreisbetter
Update. The last few days it has been quiet. Its still there, but quiet and not as loud as the day I posted the video. Found a video with the exact same sound here.
Bay Area
Old Sun, Jan-20-2019, 08:46:55 AM   #5
KAI LIN
The power should be felt not shown
Reputation: 0 KAI LIN is on a distinguished road
Taiwan
Hi,
I have the same problem.
Do you fix it? How?
Jump to top KAI LIN is offline   Reply With Quote
Old Mon, Jan-21-2019, 06:54:14 PM   #6
moreisbetter
It was the flywheel pressure plate mechanism that broke. The clutch was worn and needed to be replaced too, which exacerbate the problem. It goes away when the clutch is engaged because while the clutch is engaged, nothing is moving around. When the clutch is not engaged, things were free to move around and what you are hearing is the banging of metal components in the transmission.
Bay Area
Old Thu, Jan-24-2019, 06:46:51 AM   #7
KAI LIN
Taiwan
@moreisbetter
Thank you for your precise reply.
KAI
Discussing Help me find what this noise is in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
