Old Mon, Jul-17-2017, 02:15:58 PM   #51
BTB
BTB's Avatar
Default Re: Pentosin MTF2 Discontinued
If LT3 is wrong for the e9XM, probably best to get his switched out, as well!
You're right.. he's not going to be happy though as he just changed it for the first time by himself. It's gonna take some convincing
My Journal
Old Mon, Jul-17-2017, 02:18:57 PM   #52
bigjae1976
Default Pentosin MTF2 Discontinued
It's a total pain unless you have this. Makes life swell again. I have separate ones for my trans and diff.
Long run it costs less than buying those stupid $10 transfer pumps that always fall apart.
https://www.ecstuning.com/b-motive-p...0aAutgEALw_wcB
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Mon, Jul-17-2017, 02:45:37 PM   #53
BTB
BTB's Avatar
Good call, I believe there's a few of those little pumps laying around my dad's garage right now that are broken.. lol
I bought a Motive brake bleeder that I still have yet to use, wonder if that would work just as well
My Journal
Old Mon, Jul-17-2017, 02:46:38 PM   #54
bigjae1976
That sucks...you need blow.
Old Mon, Jul-17-2017, 02:48:20 PM   #55
BTB
BTB's Avatar
Doesn't it blow to keep positive pressure on the brake system while opening the bleed valve(s)?
My Journal
Old Mon, Jul-17-2017, 02:49:02 PM   #56
I have a dedicated MTF2 Motive pump and a dedicated e46 M3/e39 M5 diff fluid pump.
They work really well!
Super convenient having all cars use the fluids... right until said fluids are discontinued.
Old Mon, Jul-17-2017, 02:50:48 PM   #57
bigjae1976
Duh...I was thinking of a vacuum bleeder.
I guess you could but the biggest pain is cleaning those units. I'm willing to waste some money to save myself the hassle.
Old Mon, Jul-17-2017, 02:53:07 PM   #58
BTB
BTB's Avatar
Lol...
Yeah I guess that wouldn't be worth it.. I don't want oil in my brake lines and/or brake fluid in my trans!
My Journal
Old Mon, Jul-17-2017, 04:42:48 PM   #59
I thought the BMW tranny fluids got thinner and thinner for fuel economy reasons. So LT2 was lighter than LT1 and LT3 the lightest.
Here's a VOA on MTF LT3 showing k visc @ 100cSt as 6.1 which is very low, atf low. Our MTFLT2 is 7 iirc - I'll double check. EDIT: MTF-LT2 is 7.5 @100 cSt
IIRC, Lt1 was like 7.7. So heavier to lighter LT1 > LT2 > LT3 BTB - where did you get the idea that LT3 was a 75w90? A 75w90 would be around 9-10 @100cSt
_
Old Mon, Jul-17-2017, 06:13:40 PM   #60
BTB
BTB's Avatar
This eBay link
My Journal
Discussing Pentosin MTF2 Discontinued in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
