Old Tue, Apr-12-2011, 03:39:41 PM   #31
daver408
daver408's Avatar
Reputation: 0 daver408 is on a distinguished road
Default Re: Leaking Power Steering Pressure Hose - WHat to do ?
I replaced mine new and it was leaking again on the next oil change, very bad design. Its a very slow leak that is just wet around the joint hoses rather than a dripping leak, I check the PS reservoir every now and then and dont need to add any fluid ever.
Jump to top daver408 is online now   Reply With Quote
Old Wed, Apr-13-2011, 10:43:47 PM   #32
ICE68
ICE68's Avatar
Reputation: 0 ICE68 is on a distinguished road
Has it effected the stiffness of the steering yet?
Jump to top ICE68 is offline   Reply With Quote
Old Fri, Apr-29-2011, 12:17:33 PM   #33
Phant0m
Phant0m's Avatar
Reputation: 0 Phant0m is on a distinguished road
Here's a question: does anyone have an explanation as to why the hose is as long as it is and routed like this?
Mine blew out the other night... I have a surplus of -6 teflon hose, so I'm probably going to build my own replacement.
Jump to top Phant0m is offline   Reply With Quote
Old Fri, Apr-29-2011, 03:23:13 PM   #34
bolecailey
Reputation: 0 bolecailey is on a distinguished road
Mine is leaking to. I am thinking about just make one out of stainless lines.
Jump to top bolecailey is offline   Reply With Quote
Old Fri, Apr-29-2011, 05:29:19 PM   #35
mukkuz
Reputation: 0 mukkuz is on a distinguished road
Autohauz Az has good rates and free shipping
Jump to top mukkuz is offline   Reply With Quote
Old Thu, May-05-2011, 04:54:29 AM   #36
Phant0m
Phant0m's Avatar
I built my own hose this evening, installed on car and refilled the system. Too late for a drive but I'll get to that tomorrow. I have pictures if anyone is interested.
Old Fri, May-20-2011, 02:22:29 PM   #37
ekim
Reputation: 0 ekim is on a distinguished road
+1! I just bought one for $130.
http://www.autohausaz.com/search/pro... Steering Hose
'06 SMG Coupe, Carbon Black/Cinnamon, Premium, Cold Weather & Nav Packages, Power Sunshade.
Mods: OEM ZCP's, Koni's, 3M Clear Bra on all leading surfaces, Clear Reflectors, MTec Aluminum Pedals, 3M 35% Tint, Hardwired V1, Focal K2P's and 27V2 in a Wicked CAS box, Alpine PDX 5
Jump to top ekim is offline   Reply With Quote
Old Fri, May-20-2011, 03:00:38 PM   #38
Cloudsurfer
Reputation: 0 Cloudsurfer is on a distinguished road
I'm assuming the length is there to allow for some cooling, but more than likely in the real world (at least non-track), you could get away with taking out most of the length. I'd rather see the whole thing either Aeroquip hose or hard piped. Those crimp joints always seem troublesome.
Jump to top Cloudsurfer is offline   Reply With Quote
Old Fri, May-20-2011, 07:24:04 PM   #39
Cloudsurfer
I'm thinking of making up my own hose here now. Does anyone have a used stocker I can use to start with? Send me a PM if you do please....
Old Mon, Jun-06-2011, 04:54:20 PM   #40
ekim
Originally Posted by ekim View Post
I thought I had it ordered. Apparantly, the aftermarket manufacturer of this hose, Burgaflex, is no longer making the hose. I called them directly to find out why it was on backorder everywhere and was told they no longer make it. Most of the places I called (including AutohausAz) that have it on backorder have no clue that it is not manufactured anymore by Burgaflex. The only replacement is the prone to failure OEM BMW hose. At least it has a two year warranty!
hose, leaking, power, pressure, steering
leaking power steering hose... mmmpowr Faults, Fixes and DIY 1 Tue, May-13-2008 03:21:35 AM
power steering pressure hose leak 1tuan E46 M3 (2001-2006) 0 Thu, Apr-17-2008 03:46:51 AM
Power steering hose johnj3nks E36 M3 (1992-1999) 2 Wed, Jul-19-2006 10:48:28 PM
Power steering hose $$$ any substitutes? chafuro786 E36 M3 (1992-1999) 8 Mon, Jan-17-2005 06:22:06 PM
Discussing Leaking Power Steering Pressure Hose - WHat to do ? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
