Old Tue, Jul-11-2017, 07:35:07 AM   #21
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
Default Re: What Transmission Fluid? Where to buy?
I'm using Motul gearbox lube; it was suggested by the ECS rep. I used the factory fill for 10+ years except recently when ECS did not have the genuine BMW gearbox lube on the shelf.
About that Motul lube, it has made the shifting feel much more precise and weighty, surprising enough. The shift feel has never felt better, but I have to go through this awkward routine EVERY MORNING: slot into reverse to back out the driveway, and stop; while stopped, clutch in again and gently move the stick in and out of both 1st and 2nd gear. Slot it into 1st and move off slowly, then STOP; clutch in and again move the stick gently in both 1st and 2nd gear. Then and only then will 2nd gear slot in precisely with normal shift lever effort.
Since using Motul, that first shift into 2nd gear will not happen with normal lever effort after the M sits overnight. There is simply too much resistance so naturally I do not force the matter. Other than this strange ritual, the gearbox shifts beautifully and almost has a bit of that 1903 Springfield or Mauser rifle bolt precision feel, so to speak, like that in a S2000. I would not suggest using Motul in a SMG gearbox.
Jump to top Speed Monkey is online now   Reply With Quote
Old Tue, Jul-11-2017, 01:36:34 PM   #22
SliM3
SliM3's Avatar
If I'm reading correctly GL-4 is old news and pretty much obsolete.
GL-4; Specified for hypoid gear service under severe service but without shock loading. This classification is essentially obsolete but is still specified by some manual transmission/transaxle manufacturers. Implies an EP/AW additive package that contains 30% to 50% less S-P additives than the GL-5 service classification. Some Marine Gear Lubes fall into this classification, especially the full Synthetic Marine Gear lubes and specialty blenders MT lubes that use high levels of esters.
GL-5; Specified for hypoid gear service but with shock loads and severe service operation. Usually meets Mil-L-2105D and in most cases, is the multipurpose automotive gear oil. Most 75W90 to 75W140 grades meet the GL-5 classification. This grade has a high level of Extreme-Pressure additives that could be mildly corrosive to nonferrous parts, such as brass, bronze and aluminum parts. Most of the modern GL-5 lubes contain metal deactivators that prevents attacks by the extreme-pressure additives. In addition to EP additives, these lubes contain rust inhibitors, defoamants, friction modifiers, thickeners, and Viscosity Index Improvers.
As mentioned, I've had no issues with my current fluid + I shift upwards of 8500-8800. +10 years on these cars and I'm almost positive fluid technology has changed significantly. One of the reasons I switched SMG and PS fluid to a DEX/Merc VI, which rates far better than the Pentosin.
Old Tue, Jul-11-2017, 03:59:21 PM   #23
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
You aren't reading correct. GL-4 and GL-5 designations have nothing to do with syncro oil specs, which is half of proper transmission oil selection. They denote how it functions as a gear oil.
Good chance most GL-5 oils will destroy your syncos over time as they eat(peel is probably a more accurate term) yellow metals, but ultimately you are free to make whatever decisions you want.
WTS - OE CSL Trunk, Mint Condition, Uninstalled and with Hardware - $1150
911 Journal/Build Thread
Old Tue, Jul-11-2017, 04:33:24 PM   #24
For hypoid gears, yes. That's why our rear ends call for a GL5.
_
Old Tue, Jul-11-2017, 04:38:48 PM   #25
I have 22 bottles of Pentosin MTL2 en route to me
Old Tue, Jul-11-2017, 04:59:32 PM   #26
babydocjd
babydocjd's Avatar
Reputation: 0 babydocjd is on a distinguished road
That sounds like a terrible routine.
///M Life
Jump to top babydocjd is offline   Reply With Quote
Old Tue, Jul-11-2017, 05:11:35 PM   #27
MrVond
The Phanto///M
Reputation: 0 MrVond is on a distinguished road
i just changed to ravenol mtf-2
[2006 E46 M3 | Competition Package | Interlagos Blue | Black | AFE Intake | Enkei MT1 | SMG ---> 6MT | Fortune Auto 500 ]
[2011 E90 M3 | Competition Package | Jet Black | Extended Fox Red | AFE Intake| AFE Exhaust | DCT GTS]
Jump to top MrVond is online now   Reply With Quote
Old Tue, Jul-11-2017, 05:14:28 PM   #28
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
I'm using Redline MTL 75w80 (GL-4) and I haven't had any issues so far. In fact, I'm due for an Inspection I soon so I'll be doing a tranny fluid change with more Redline MTL. It's about $17/qt from ECS.
JaredMV's M3 Touring Build: http://www.m3forum.net/m3forum/showthread.php?t=604213
Jump to top JaredMV is online now   Reply With Quote
Old Tue, Jul-11-2017, 05:55:38 PM   #29
Ya I think this is our other option. It's the exact same spec as stock.
Here's a little more info:
https://www.bobistheoilguy.com/forum...Number=2987835
_
Old Wed, Jul-12-2017, 07:19:26 AM   #30
bimmerdriver
^ There's literally no useful info from that video. No science, no details. IF we can find that their GL-5 doesn't have the common eps that are always found in GL5 gear lubes, then that's a start, but only half the equation. Does their GL5 lube contain the FMs found in GL4 lubes for proper synchro action?
I don't know, the CRP guy was condescending, but didn't give any real info.
What we do know, for a fact, is that our tranny calls for a 75w80 GL4 and our diff, a 75w140 GL5. Until I can find more info, I'll do my best to always use the right spec. At least I have 2L of new MTF2 which should last me for a long time, but still a shame that MTF2 has possibly been discontinued - do you have a link to where you got that info?
Agreed, the video is somewhat useless.
Here is a link to Pentosin's 2016 product sheet, which says MTF2 is to be discontinued. On ECS Tuning's website, it says it's discontinued. So anyone seeing it at various places is probably seeing existing inventory that will not be restocked.
Discussing What Transmission Fluid? Where to buy? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
