Old Fri, Jul-07-2017, 11:59:09 PM   #11
Default Re: What Transmission Fluid? Where to buy?
I feel like I've seen the 5L jugs (Pentosin had one too I thought, not just BMW) online before which would work out better for someone in your situ.
_
Old Sat, Jul-08-2017, 12:13:05 AM   #12
That's what I've bought to date.
Old Sat, Jul-08-2017, 02:46:15 AM   #13
RedM3/4
I'm with tbone on this, stay with spec. Castrol and Pentosin were OEs in different markets close as I can find, but I expect other 75w80 GL4's would be fine if you find/have those.
Do NOT use Redline ATF or any other atf; Redline "says" it's the proper application for our trannies, it is not. ATF may be the spec on lower HP/torque applications for the 420G, but it isn't for the E46 or E39 M's.
ADS
Old Sat, Jul-08-2017, 03:46:01 AM   #14
delvin
Water Champion
Reputation: 0 delvin is on a distinguished road
Default What Transmission Fluid? Where to buy?
disregard
Jump to top delvin is offline   Reply With Quote
Old Sat, Jul-08-2017, 12:51:50 PM   #15
PSUEng
ADS
I can attest to this especially in the case of the Royal Purple Synchromax (ATF) that is supposedly for our cars...it feels to thin when shifting. Back in went the Pentosin MTF2 and feels great. Stick with OE spec.
Old Mon, Jul-10-2017, 01:57:12 AM   #16
D-O
Reputation: 0 D-O is on a distinguished road
Hello,
It is my understanding that the issue with GL-5 and transmissions is that GL-5 will corrode yellow metals (copper/brass). However, fluids that are spec'd to meet both GL-4 and GL-5 have additive packages that include "corrosion inhibitors and metal deactivators" that have eliminated this problem.
FWIW.
Jesse
Jump to top D-O is offline   Reply With Quote
Old Mon, Jul-10-2017, 04:44:02 AM   #17
DanAvoN7
Reputation: 0 DanAvoN7 is on a distinguished road
Pentosin MTF2 was discontinued so if you happen to find some it is older inventory. Pentosin now recommends their FFL4 fluid which can be used in place of MTF2. Video they released with more info
04 BMW M3 6spd - Alpine White/Black
Apex ARC-8 w/ Hankook Z214, Apex ARC-8 w/ BFGoodrich R1, MCS 3-way Coilovers, GC Race Camber Plates, PFC BBK, Turner Camber Arms, Turner Sway Bars, Turner Subframe bushings, Turner Solid Diff Bushings, Turner Solid RTAB, Turner Solid Control Arm bushings, Treehouse Racing FCAB, Reinforced Subframe, OS Giken LSD, Rogue Engineering Transmission Mounts, SGT Headers, SGT Section 1, AFE Stage 2 Intake, EPIC Tune, Dinan Exhaust, Bimmerworld Airdam/Splitter/Dive Planes, Bimmerworld V2 Wing, TC Design Roll Cage, Racetech RT4119, Scroth Profi 2 Harness
NORCAL Rod Bearing/Vanos/Valve Adjustment/Inspections Member Feedback
Jump to top DanAvoN7 is offline   Reply With Quote
Old Mon, Jul-10-2017, 06:13:32 AM   #18
^ There's literally no useful info from that video. No science, no details. IF we can find that their GL-5 doesn't have the common eps that are always found in GL5 gear lubes, then that's a start, but only half the equation. Does their GL5 lube contain the FMs found in GL4 lubes for proper synchro action?
I don't know, the CRP guy was condescending, but didn't give any real info.
What we do know, for a fact, is that our tranny calls for a 75w80 GL4 and our diff, a 75w140 GL5. Until I can find more info, I'll do my best to always use the right spec. At least I have 2L of new MTF2 which should last me for a long time, but still a shame that MTF2 has possibly been discontinued - do you have a link to where you got that info?
_
Old Mon, Jul-10-2017, 12:02:31 PM   #19
Feffman
Grand Poobah
Feffman's Avatar
Reputation: 0 Feffman is on a distinguished road
Gents:
I was in NAPA (big new store) last weekend and they had Pentosin MTF2 on the shelf. If need be, they can order it for you: https://www.napaonline.com/en/p/AOR8056107
Feff
MVP Track Time
Jump to top Feffman is offline   Reply With Quote
Old Mon, Jul-10-2017, 02:57:20 PM   #20
Drewster
Drewster's Avatar
ADS
Same. Ordered Redline via Turner when I got the car because someone recommended them, ended up switching to Pentosin
Discussing What Transmission Fluid? Where to buy? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
