Old Tue, Jul-16-2019, 07:35:55 AM   #1
Za Rulem
Reputation: 0 Za Rulem is on a distinguished road
Default Avin Avant 4 steering wheel buttons not working
Can't make steering wheel work with Avant 4. All other functions work fine. Avin even sent me a different Canbus box that didn't help.
My question for people who installed the unit, did it work for you our of the box?
When you went to Settings -> Car -> Steering wheel controls, did you see buttons right away or you had to press the buttons to detect them?
I connected 17-pin main cable in 3 places - to the car harness, Avant 4 unit and canbus box. Extra single wires not used. Did you use the same setup?
Avin support is lacking, installation instructions are scattered in 20 documents and videos.
Thanks.
Jump to top Za Rulem is offline   Reply With Quote
Old Tue, Jul-16-2019, 01:04:39 PM   #2
Hauptm
Reputation: 0 Hauptm is on a distinguished road
Default Re: Avin Avant 4 steering wheel buttons not working
I didn't see this when I installed. Also, didn't have to do any additional setups.
Sorry you're having the issue.
- Mark
'04 E46 M3 Vert, Silver Gray Metallic, Dove Gray, SMG
Jump to top Hauptm is offline   Reply With Quote
Old Wed, Jul-17-2019, 04:17:28 PM   #3
norcal420
mass nerder
norcal420's Avatar
Reputation: 0 norcal420 is on a distinguished road
My Avant 4 also didn't have the steering wheel buttons working. I too received a new Can Bus adapter that didn't fix the issue. I checked settings as well and mine was set to 'SWC key', but I tried all three options (disable, Can key, SWC key) and nothing fixed it.
I'm returning the unit for a new one.
Jump to top norcal420 is offline   Reply With Quote
Old Fri, Jul-19-2019, 09:01:49 AM   #4
Za Rulem
@norcal420 I've searched everywhere in settings and couldn't find Can key/SWC key setting. Where is it? In some other app?
Thanks!
Discussing Avin Avant 4 steering wheel buttons not working in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
