Old Mon, Jul-15-2019, 10:11:15 PM   #1
sapote
Default Washer pump short life and potential solution
Our cars and the normal E46 use the same washer pump for front windshield, and it is a bad design product with short life. I heard Toyota owners don’t need to replace the pump as often – last longer than the car mostly.
Over the weekend I installed a Toyota Denso pump on my 323i, and I will study if the M3 tank can use the same pump. Here’s the link:
https://forum.e46fanatics.com/showthread.php?t=1258691
Old Tue, Jul-16-2019, 04:30:30 AM   #2
Texaz3
Default Re: Washer pump short life and potential solution
Yeah, okay.
Old Tue, Jul-16-2019, 05:41:48 AM   #3
icecream
Registered Apples
icecream's Avatar
Can I ask a legitimate serious question? What car did you own before this?
Old Tue, Jul-16-2019, 07:24:52 AM   #4
ThunderMoose
Sapote before “owning” his first M3
Old Tue, Jul-16-2019, 08:21:40 AM   #5
Altaran
Reputation: 0 Altaran is on a distinguished road
Germany
Most windshield washer pumps are similar.
You can also use VW washer pumps, the use the same bottom inlet design and connector.
Just make sure you get the mono pump for a coupe or convertible.
Gesendet von meinem LON-L29 mit Tapatalk
Jump to top Altaran is offline   Reply With Quote
Old Tue, Jul-16-2019, 06:23:46 PM   #6
sapote
This is correct, that they all have a motor, rubber seals, and an impeller, but the similarity end here. BMW pump has bad seal design allowing water to leak into the motor chamber and rusted rotor, then locked up. Toyota pumps don't have this issue. My '67 Porsche original washer pump still works.
Old Tue, Jul-16-2019, 06:40:27 PM   #7
I'm on my original pump
Old Tue, Jul-16-2019, 06:52:06 PM   #8
sapote
Horses, bicycles, 1963 Vespa 125cc, 1957 Triumph TWN Super Tessy 150cc, 1957 Micoletta 250cc, 1964 Fuji Rabbit, 1967 Ducati 125 Sport, 1977 R100S.
Old Tue, Jul-16-2019, 06:54:24 PM   #9
Mine did fail. And I think the replacement has an internal leak or something since it takes a couple seconds before it builds enough pressure to spray.
Old Tue, Jul-16-2019, 06:58:02 PM   #10
Drewster
Drewster's Avatar
Thank god, I can sleep soundly at night now that this has been resolved.
Discussing Washer pump short life and potential solution in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
