Old Mon, May-06-2019, 02:18:39 PM   #1
UFoh
Reputation: 0 UFoh is on a distinguished road
Default Bad fuel leak when gas pump tops off!
Hey guys. I get a really bad fuel leak when topping off the gas. Does anyone have any idea what it could be? I took the right rear tire off and the plastic guards and I don't see any obvious leaks. I'm going to go get gas and get my friend to fill it up while I stand under it, but I figured I would ask if y'all have any specific ideas on where I should be looking? In my head I was gonna see obvious wet spots but I don't.
https://i.imgur.com/StxIxj9r.jpg
Jump to top UFoh is offline   Reply With Quote
Old Mon, May-06-2019, 03:46:48 PM   #2
Pnick
Pnick's Avatar
Reputation: 0 Pnick is on a distinguished road
Default Re: Bad fuel leak when gas pump tops off!
One area besides the top of the gas tank/fuel tank mating surface is the formed hose from filler pipe to tank connection union.
05-SMG/IB/CINN/ZCP/SUNROOF_DELETE
If they don't meet your standards, lower yours!
Jump to top Pnick is offline   Reply With Quote
Old Tue, May-07-2019, 03:45:37 AM   #3
UFoh
Hey, thanks a bunch for your reply Pnick. I looked where you told me to and there it was. I called jb weld and they told me to use jb plastic bonder. I applied it with a small paintbrush and it seems to have totally fixed my leak. I probably wouldn't have spotted it without ya
Old Tue, May-07-2019, 04:41:11 PM   #4
Pnick
Pnick's Avatar
Glad I was able to help...I won't trust that JB stuff on fuel hose though...I'd figure out a way to replace it if I were you...Fire is not something you want happening..
Old Tue, May-07-2019, 04:43:55 PM   #5
Old Tue, May-07-2019, 04:52:22 PM   #6
I wouldn't ever top off any car, and I wouldn't trust JB weld when a fuel leak is the result if it goes south.
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5,04 M3 wagon, 2017 i3
Discussing Bad fuel leak when gas pump tops off! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
