Old Wed, Dec-15-2010, 05:25:43 PM   #1
Cipri
Reputation: 0 Cipri is on a distinguished road
Romania
Default E46 M3 - Dyno
At the base is an euro model M3, 6MT - 343 hp
Engine mods: K&N panel filter + Rogue Engineering power pulleys (street version)
I think the power increase is very good.
///M (2002 - 360 HP)
Performance: Rogue Engineering Power Pulleys, K&N panel filter, 4.10 Differential
Exterior: OEM CSL Carbon Roof, Seibon Carbon Hood, 19" CSL Wheels + Toyo Proxes R1, Polycarbonate Margard Rear Window
Interior: Seibon Carbon Seats
Jump to top Cipri is offline   Reply With Quote
Old Wed, Dec-15-2010, 05:27:14 PM   #2
azngolf
azngolf's Avatar
Reputation: 0 azngolf is on a distinguished road
Viet Nam
you added 10HP with just those mods? interesting
03.5 SG:
CURRENT MODS
A little here and little there...
Jump to top azngolf is offline   Reply With Quote
Old Wed, Dec-15-2010, 05:28:27 PM   #3
kmfurdm
Oceania
kmfurdm's Avatar
Reputation: 0 kmfurdm is on a distinguished road
England
European cars are more powerful out of the box.
evolve-R -- AFe Stage 1 -- Turner pulleys -- SuperSprint V2s -- Euro Section 1 -- Dinan muffler -- TC Kline D/A 500F/500R + TCK Camber Plates -- autosolutions 20% SSK -- Volk RE30 Hyper Bronze
Jump to top kmfurdm is offline   Reply With Quote
Old Wed, Dec-15-2010, 06:03:08 PM   #4
Quebeker
French Canadian User
Quebeker's Avatar
Reputation: 0 Quebeker is on a distinguished road
At the crank maybe, but at the wheels....no way!
It must be some magic pulley! According to your graph, a 17HP increase... very unlikely...
Jump to top Quebeker is offline   Reply With Quote
Old Wed, Dec-15-2010, 06:04:52 PM   #5
NikolaiD
NikolaiD's Avatar
Bulgaria
OK, first off, LOL @ the name of the shop. V-TECH TUNING!
Second, it's a bit more complicated than that. Without a before and after, we don't know how much he actually gained.
Euro cars are rated at 343 DIN HP, which is 338 SAE HP, so they have 5hp more to begin with.
He dynoed 361, so at first glance, that's an 18HP increase, but we don't know two important things:
1. Was his dyno in DIN or SEA numbers. This is a 5hp difference that might have been neglected.
2. What is the driveline loss correction factor they used to simulate those numbers. Some people use a .85 conversion factor, some use .825, between them could be a 10hp difference.
Either way, that's more than I dynoed with eBay headers, glad to see your car is running strong!
MSS54 Error Codes
(work in progress)
Old Wed, Dec-15-2010, 06:10:01 PM   #6
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
Agreed that the base line from factory is ~343hp, but you don't know how that dyno is reading. You may have pulled 365hp stock on that dyno. Do you have a baseline?
Mr. Wolfe
Old Wed, Dec-15-2010, 06:42:44 PM   #7
TMS951
Reputation: 0 TMS951 is on a distinguished road
You chart means nothing. There is no base line. The numbers are arbitrary with out a comparison to the same car on the same dyno before.
343 is the published number, there is probably a +/- 7hp one car to the next, then the margin of error on a dyno is around 5-6hp. There is not enough accuracy to properly find what the gains, if any, were.
01 M3- ESS VT2-575 - Stoptech 355 - VAC stage 3 Engine - K&W - CCW + O.Z. - much much more...
Jump to top TMS951 is offline   Reply With Quote
Old Wed, Dec-15-2010, 07:03:57 PM   #8
Cipri
Romania
azngolf: 361 - 343 = 18 hp
Quebeker: it is logical that the power is measured at the crank
NikolaiD: I do not have a dyno run before the mods, apart from the 2 mods above I use also NGK Iridium spark plugs.
The Dyno is V-tech with standard European DIN numbers, I do not know the correction factor used (I will ask for it and revert).
Mr. Wolfe: This dyno is verry accurate, I do not have to proove anything to anyone ...
I did another 2 dyno runs with 358 and 359.
Old Wed, Dec-15-2010, 07:23:21 PM   #9
NikolaiD
NikolaiD's Avatar
Bulgaria
It'd be good to get wheel horsepower, since that number is kind of "definitive". Crank HP number can be changed depending on what the dyno operator feels it should be.
I don't mean to discredit the dyno at all, it's just not a universal conversion as it is right now.
Is your ECU tuned, or stock?
MSS54 Error Codes
(work in progress)
Old Wed, Dec-15-2010, 08:12:29 PM   #10
Reach
Reach's Avatar
Reputation: 0 Reach is on a distinguished road
Weather, correction factor, crank multiplier, SAE v DIN... this is just a dyno queen sheet, sry man. Always look to before & after sheets before trying to support a statement of gained power.
Jump to top Reach is offline   Reply With Quote
dyno, e46
Discussing E46 M3 - Dyno in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
