Old Wed, Sep-29-2010, 09:12:36 PM   #1
lamboworld
Reputation: 0 lamboworld is on a distinguished road
Default Dyno after mods
First dyno run was done shortly after I purchased my M3 and it was bone stock.
1st Run 278.2hp Torque 229.4
2nd Run 278.7hp Torque 229.4
3rd Run 284.1hp Torque 226.6
I have installed the following mods before my dyno today:
Evosport Headers
400 cell CRT
ESS Tune
Borla muffler
Evosport Pullies
BMC Filter
Samco Intake Elbow
The dyno chart that I attached compares the best run from my first dyno to the best run of my dyno after mods.
11 hp increase and 9.2 torque increase.
Both dynos were done on the same machine.
I thought that my numbers would have been higher. Any thoughts?
Jump to top lamboworld is offline   Reply With Quote
Old Wed, Sep-29-2010, 09:26:55 PM   #2
Frankenstein M3
M3 Unleashed
Frankenstein M3's Avatar
Reputation: 0 Frankenstein M3 is on a distinguished road
you are at 370to the crank that is pretty good. look into correction factor, temp, humidity.
By the way what type of dyno was it done on ?
Jump to top Frankenstein M3 is offline   Reply With Quote
Old Wed, Sep-29-2010, 09:32:00 PM   #3
lamboworld
SuperFlow WinDyn
Old Wed, Sep-29-2010, 09:43:28 PM   #4
EricSMG
40 something
That baby's running way too rich above 5k.... should stay close to 13:1 for most of the tach, only dropping a point or so for the last 1k rpm. 'Course, it was ultra rich when stock.
I'd send that dyno to ESS and see what they think..... because that's way too rich for sure.
Edit: you didn't include "intake" in your list of mods, did you?? That could be throwing you way off.... your intake is stock.
Old Wed, Sep-29-2010, 10:00:15 PM   #5
|sland|2oots
|sland|2oots's Avatar
Reputation: 0 |sland|2oots is on a distinguished road
Shouldn't A/F ratios be 14.7(stoich)?
Jump to top |sland|2oots is offline   Reply With Quote
Old Wed, Sep-29-2010, 10:01:35 PM   #6
opey
opey's Avatar
Reputation: 0 opey is on a distinguished road
if the numbers werent SAE corrected, then u should have them corrected and then compare
04 IR/IR 6spd
sold =(
Jump to top opey is offline   Reply With Quote
Old Wed, Sep-29-2010, 10:04:55 PM   #7
opey
opey's Avatar
no, not under full throttle.. they should be around 13.0:1, thats a safe target for an N/A car.
04 IR/IR 6spd
sold =(
Old Wed, Sep-29-2010, 10:17:12 PM   #8
lamboworld
It looks like they did not SAE correct my dyno numbers from todays dyno. Based on this http://wahiduddin.net/calc/calc_hp_dp.htm SAE calculator looks like the corrected hp should be right at 300hp.
SAE correction was 98.3
I will see if he can correct the numbers tomorrow.
Old Wed, Sep-29-2010, 10:36:12 PM   #9
ClutchKickChris
Reputation: 0 ClutchKickChris is on a distinguished road
Have the car custom dyno tuned, those AFR's are too rich up top!
Jump to top ClutchKickChris is offline   Reply With Quote
Old Wed, Sep-29-2010, 10:48:51 PM   #10
E46M3FF
E46M3FF's Avatar
Reputation: 0 E46M3FF is on a distinguished road
wow thats a deep rise into the rich fuel area.
Jump to top E46M3FF is offline   Reply With Quote
dyno, mods
Discussing Dyno after mods in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
