Old Sun, Sep-19-2010, 03:10:10 AM   #41
DrifterX27
BussAnut
Reputation: 0 DrifterX27 is on a distinguished road
Used O2 bungs on right side to install the 2 sensors
Too close to heat shield. Even after installing in header first and then trying.
1995 Performance Motorsports SC300 6 speed 930hp| 67mm PTE 6766CEA | Custom CP Pistons | Manley H Beam Rods | Titan Billet Main Caps | Ferrea 1MM+ Valves | PHR Oil Pump | ID2000 injectors | AEM EMS V1 | Custom Cams | GTE gasket | ARP Head/Main Studs | Crower springs/retainers | Custom 3" Dual Exhaust | V160 | Custom SP One-Piece Driveshaft | TRD LSD | HKS DLI | Boost Logic Turbo Manifold | Tein Flex Coilovers | TRD Big Sway Bars | Southbend Custom clutch | My Build to 800whp |
Jump to top DrifterX27 is offline   Reply With Quote
Old Tue, Sep-21-2010, 01:27:49 AM   #42
MCK
Reputation: 0 MCK is on a distinguished road
dyno updates?
Jump to top MCK is offline   Reply With Quote
Old Tue, Sep-21-2010, 03:07:47 AM   #43
DrifterX27
BussAnut
Not yet, just fixed a leak at the header. #3 gasket for blown. Received the software, resistors, and o2 sim, so tomorrow I will be doing all of that and maybe dyno if I have time, if not then I will dyno on wednesday. Very excite!
Old Sat, Dec-11-2010, 04:12:02 PM   #44
dafoe
dafoe's Avatar
Any updates Drifter? Thanks.
Old Sat, Dec-11-2010, 04:28:39 PM   #45
vhtan00
MadSkilz
vhtan00's Avatar
Reputation: 0 vhtan00 is on a distinguished road
DrifterX27,
What type of stud/nuts are you using to secure the header? It does not look like the standard copper nut...
Vinny
Jump to top vhtan00 is offline   Reply With Quote
Old Sun, Dec-12-2010, 01:06:54 PM   #46
evolve_auto
BMW Tuning
evolve_auto's Avatar
Reputation: 0 evolve_auto is on a distinguished road
United Kingdom
Why are you guys even contemplating fitting something without pre-cat 02 sensors or using 02 sims??
In the short term your cars will run fine. In the long term however I have seen what happens. Good luck!
Why not invest in headers that a properly developed to start with. If they were developed properly the 02 bungs would be in the right place.
I am assuming the sims are being used to pass emissions??
Evolve Automotive USA
WEBSITE . EMAIL . INSTAGRAM . FACEBOOK
Jump to top evolve_auto is offline   Reply With Quote
Old Sun, Dec-12-2010, 05:42:48 PM   #47
EricSMG
40 something
Originally Posted by vhtan00 View Post
DrifterX27,
Vinny
Exactly my thoughts.... those are not OEM parts. He's likely not using OEM gaskets either... not good.
I'm very disturbed about the O2 bung placement of these headers. That's just flat unaccepatable. Complete junk in my book.
Old Mon, Dec-13-2010, 06:29:18 PM   #48
DrifterX27
BussAnut
Update:
I had used the gaskets that were supplied with the headers, and those were paper. I used the oem metal gaskets and all leaks are fixed. Did the O2 simulator box and had the O2 bung welded in the header for better fitment. Also had the Shark Injector installed and noticed a nice improvement. No CEL's and I haven't redyno'd to find out the gains.
Edit:
I did all these fixes and mods about 2 months ago. No issues so far, and no CEL's. I would like to get a nice muffler to change the sound. I had the Raceflow mid pipe installed and it sounded amazing at high rpm but crap at anything under 4000, so I removed it. Will upload a vid if I can find it.
Old Mon, Dec-13-2010, 06:54:12 PM   #49
DrifterX27
BussAnut
http://www.youtube.com/watch?v=0S0C5PeShLc
http://www.youtube.com/watch?v=Q9ip0FOM7VE
dyno, header, install, preparation
Discussing M3 dyno, preparation for header install in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
