Old Mon, Sep-13-2010, 01:55:52 AM   #31
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
wasn't part of the install to bend the heatshield a bit, so that the o2 sensor would fit?
any pictures of the bungs where they were, vs where they should be?
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Mon, Sep-13-2010, 02:00:53 AM   #32
MarkOne
I plead the FiF
MarkOne's Avatar
Reputation: 0 MarkOne is on a distinguished road
yeah, id like to know as well. i havent received my headers yet but would like to at least get a general idea on the o2 issue.
"I then just left that Ho in my rear view"- ///M3PhrEAk
SOLD
2005 Carbon Black on Black M3 Coupe w/ SMG
Current Mods: M3an One headers, OEM euro section 1, K&N drop in filter, OEM zcp brakes, ECS brake lines, ST coilovers, Linea Corse LM reps (19x8.5 +35, 19x10 +22), Khoalty license plate LEDs, Turner painted reflectors, Depo matte black kidney grills, Depo smoked corners, Depo smoked side markers, EAS cf 2x2 interior trim, BSW subwoofer
Jump to top MarkOne is offline   Reply With Quote
Old Mon, Sep-13-2010, 03:35:38 AM   #33
Reach
Reach's Avatar
Reputation: 0 Reach is on a distinguished road
I would like to know what the brand of the headers were that were sent to you. I'm wondering if they were the M2 headers, with the known bad bung location.
I find it completely unacceptable that a member would be selling these headers if they can't be installed correctly due to bad bung location. I would be furious if I had got these!
Jump to top Reach is offline   Reply With Quote
Old Mon, Sep-13-2010, 07:00:34 AM   #34
DrifterX27
BussAnut
Reputation: 0 DrifterX27 is on a distinguished road
I would have to remove a bunch of crap if I were to get pics of the headers. I will do it when I get the software in since I will have to install that at the auto shop.
1995 Performance Motorsports SC300 6 speed 930hp| 67mm PTE 6766CEA | Custom CP Pistons | Manley H Beam Rods | Titan Billet Main Caps | Ferrea 1MM+ Valves | PHR Oil Pump | ID2000 injectors | AEM EMS V1 | Custom Cams | GTE gasket | ARP Head/Main Studs | Crower springs/retainers | Custom 3" Dual Exhaust | V160 | Custom SP One-Piece Driveshaft | TRD LSD | HKS DLI | Boost Logic Turbo Manifold | Tein Flex Coilovers | TRD Big Sway Bars | Southbend Custom clutch | My Build to 800whp |
Jump to top DrifterX27 is offline   Reply With Quote
Old Fri, Sep-17-2010, 04:30:58 AM   #35
DrifterX27
BussAnut
Installed pre cat o2's. And ordered the o2 simulator and resistors. My filter is here now and the software will be here on monday. Still gotta re-tighten the lower header bolts, have an exhaust leak at the header.
Old Fri, Sep-17-2010, 05:01:39 PM   #36
lsb
lsb's Avatar
Reputation: 0 lsb has disabled reputation
Where did you order your o2 simulators and resistors...i tried from o2simdotcom but it wouldn't go through.
Jump to top lsb is offline   Reply With Quote
Old Fri, Sep-17-2010, 05:03:13 PM   #37
DrifterX27
BussAnut
www.o2sim.com
Old Sat, Sep-18-2010, 09:59:22 PM   #38
BlownE46M3
Reputation: 0 BlownE46M3 is on a distinguished road
Can you take the header photo in the group buy thread, add arrows pointing to the best location for new bungs and post it? It would help avoid the install, 02 clearance problems as people would be able to make the modifications before they start the install.
Jump to top BlownE46M3 is offline   Reply With Quote
Old Sat, Sep-18-2010, 11:19:02 PM   #39
DrifterX27
BussAnut
I took some yesterday actually. Gotta upload them.
Old Sun, Sep-19-2010, 02:22:26 AM   #40
BlownE46M3
great, thanks!
dyno, header, install, preparation
Discussing M3 dyno, preparation for header install in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
