Old Wed, Jul-04-2018, 05:52:26 AM   #321
Default Re: Tyler's "Better late than never" 2004 SG 6MT Slicktop Journal
Ha! I know Paulo, I know. Yes, yellow, what else
Added some more cool photos. You'll see some brass hardware my dad put in the calipers to avoid metal shavings getting in, but I'm leaving them in since they'll also work perfectly as cover when I clean and then paint. Thanks dad!
Hoping to strip/prep the old paint, cover the seals and start laying some coats of yellow down tomorrow, got the day off
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats zero options ~3200lbs JOURNAL
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies WPC'd OE bearings oil catch can fan/SAP/washer delete CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/550) + tall RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates SPC alum rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
OE CSL trunk Sportline 8S 18"x8.5/9.5" MPSS 245/275 APEX 75mm Studs 12mm/10mm F/R spacers Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Wed, Jul-04-2018, 09:38:24 AM   #322
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Default Re: Tyler's "CSL lite" 2004 SG 6MT Slicktop OE+
Nice one bro
Jump to top 0-60Motorsports is offline   Reply With Quote
Old Fri, Jul-06-2018, 06:12:39 PM   #323
Got some more progress to share. Started cleaning, stripping, sanding the passenger caliper. Covered the pistons and seals just with duct tape. Used 3M Scotch pad, green and a brass brush. Acetone is working well, but elbow grease is still required. Make no mistake about it, this is where you earn your DIY discount!
First coat
Second coat, got dark, so finished for the night. I want to do another coat or two. Then I'm going to make an outdoor "oven" for these to "bake" more. Got lucky with this 100 degree heatwave this weekend, perfect for curing these babies!
_
Old Fri, Jul-06-2018, 07:01:41 PM   #324
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Reputation: 0 KhanArt is on a distinguished road
DIY discount but the feeling in the end that you did it yourself
2004 Jet Black/Cinnamon 6spd ///M3
Build///Journal
IG: @Khan_Art_
Jump to top KhanArt is offline   Reply With Quote
Old Fri, Jul-06-2018, 07:07:40 PM   #325
That's what it's about!
_
Old Sat, Jul-07-2018, 02:01:32 PM   #326
Paulo M
Originally Posted by TboneM3 View Post
Edit: nvm found correct part# 51718208646
So did you ever find this rubber seal? I looked and mine seems to have the exact tear. The part# on realoem is showing it’s discontinued.
BREMBO BBS DIXIS
Old Thu, Jul-12-2018, 04:34:30 AM   #327
M3_Pilot
What size rotors are you using? With your Porsche calipers.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Thu, Jul-12-2018, 05:33:51 AM   #328
Paulo, I haven't even looked yet, but thanks for putting the #! So it looks like it's somehow lol, very cheap! Replacement will probably be difficult
https://www.fcpeuro.com/products?key...SAAEgJvF_D_BwE
Pilot, 345mm OE csl/zcp/z4
_
Old Thu, Jul-12-2018, 05:57:42 AM   #329
I may as well dump some photos of more progress...
Started in on the driver caliper
4 coats now on the passenger one
Laid down coats on the bottom of #2, and #1, even after a day, because of this 100+ heat, has hardened well.
While waiting, I just thought of spraying the exposed portion (once installed) of the rotor with a high temp clear. Perhaps this will preserve the look? Maybe brake dust will wash off and surface rust won't even happen?
You know me, I polished the exposed portion. Once done, I used mineral spirits and wiped again and removed more residue even though I couldn't see it - an important step before painting.
2 coats, dry in no time. Very glossy
Back to the calipers. The rest of the parts arrived. The Creations Motorsports brackets are pretty sweet, but they're unfortunately pretty heavy. I suppose the other brackets will be similar since quite a bit of material is needed to secure these adequately. The calipers themselves are so light, it's still a tangibly better feeling change from stock.
The lines are very cool, braided but also teflon coated. I also bought new pad backing damper plates. It's costly (if trying to be budget), but worth it. I'll list all costs at the end.
Laid down the BREMBO high temp decals. Just a strip of tape to keep me straight. It's not perfect, but I'm happy.
They went on well, here's the link: https://www.ebay.com/itm/BREMBO-Brak...53.m2749.l2649
2 coats of 2000 clear. I cover the box and they'll cure for over a week before install.
Then I put the bleeders in:
I've also decided to replace the wheel hubs. It's the perfect time and I have 176k so better do it. I have no real symptoms, perhaps a little more interior road noise, but I bet they're almost done inside. I also bet and look forward to how much nicer the car should roll.
Got the OE F.A.G hubs and all the little dustshield/nuts. You need a thin wall 6 or even 12 pt 1/2 or 3/4 drive 46mm or 1&13/16 though some say 1&7/8. Then a 36mm to tap the new one on the spindle or round stock of a usable dia. A 3 jaw puller might help get the old one off depending on how stuck it is. Luckily, memeber "Good" already has the big socket I can use.
I leave you with this
_
Old Thu, Jul-12-2018, 08:23:17 AM   #330
Kwakjoe
Kwakjoe's Avatar
Reputation: 0 Kwakjoe is on a distinguished road
Your car’s basically brand new
Jump to top Kwakjoe is offline   Reply With Quote
Discussing Tyler's "Better late than never" 2004 SG 6MT Slicktop Journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
