Old Fri, Aug-11-2017, 02:45:26 PM   #1
Netman
Reputation: 0 Netman is on a distinguished road
Default Stranded again
On my way to Kelowna for the airbag recall and the car starts to shimmy a bit. Check engine light comes on and I pull over. Checked the codes and it says cylinder 6 misfire. The code won't clear and of course the car won't turn over now. So what misfortune have I stumbled upon this road trip?
Jump to top Netman is offline   Reply With Quote
Old Fri, Aug-11-2017, 02:57:15 PM   #2
T-Rex
Reputation: 0 T-Rex is on a distinguished road
Default Re: Stranded again
How old are the coils/plugs?
Jump to top T-Rex is offline   Reply With Quote
Old Fri, Aug-11-2017, 03:02:58 PM   #3
Netman
Plugs are new but not sure on the coils. Just waiting for a tow now.
Old Fri, Aug-11-2017, 03:20:17 PM   #4
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
Ahh yes... The gremlin known as Mr. Ignition Coil has decided to pack-up and go on vacation with you. Your codes are probably the P30X variety, for engine misfire. Order up some new coils and spark plugs; this should fix it. As a side when it comes to plugs, I've used iridium plugs for a long time; I decided to go with the stock dual electrode type and I gotta say, the stock plugs feel a bit smoother and the engine feels a smidge stronger at higher Rs - well, that's my commentary on my experience of late.
Jump to top Speed Monkey is online now   Reply With Quote
Old Fri, Aug-11-2017, 03:27:11 PM   #5
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
IDK......Car should still run with one dead coil. Just rough.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ SGT 1 piece lip
Jump to top Sandeep1212 is online now   Reply With Quote
Old Fri, Aug-11-2017, 03:32:20 PM   #6
rpearl555
So Shiny So Chrome
Reputation: 0 rpearl555 is on a distinguished road
I had a bad coil
Car ran like a Harley and would crank when requested
Old Fri, Aug-11-2017, 03:33:32 PM   #7
lmtfi
lmtfi's Avatar
Guess: Coil(s). You should have a spare coil. Sucks to be in limp mode on trips.
Old Fri, Aug-11-2017, 03:47:42 PM   #8
bluptgm3
How old are Pre-cat O2s?
Old Fri, Aug-11-2017, 05:14:20 PM   #9
icecream
Registered Apples
icecream's Avatar
Un plug the maf and see if it starts.
Old Fri, Aug-11-2017, 05:25:22 PM   #10
Netman
Had it taken to an Indy shop in Kamloops, just waiting for them to have a look. On a side note the car did start but ran very rough. Shut it down and waited 10 minutes and tried again but didn't turn over. That's what worries me.
Discussing Stranded again in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
