Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E46 FAQ
Closed Thread
Old Sun, Jun-27-2004, 09:22:58 AM   #1
Beowoulf
Grumpy
Beowoulf's Avatar
Reputation: 0 Beowoulf has disabled reputation
United Nations
Default Adjusting passenger side mirror tilt
Explination courtesy of Cowboy Bebop
Place the selector switch into the right (passenger side) position, then shift into reverse.
does the mirror move?
If it does not, then your mirror is "INACTIVE" and needs to be taken into the dealer and switched to the ACTIVE mode with their computer.
when "ACTIVE" the switch positions will swap so that the mirror now moves only when in the right position.
since this is the position in which you adjust the mirror anyway all you do is turn the key, place the gear selector in R- adjust the mirrow with the switch to whatever position you want it to be in, turn the key off and lock the car.
there you have it.
from that point you will always have the mirror in that position when you place it in R.
Mine tilts down first, then pulls in toward the body.
this is all dependent on your having Power seats. It will not work otherwise.
Alex
Jump to top Beowoulf is offline
Old Sat, Jan-28-2006, 01:04:37 AM   #2
Beowoulf
Grumpy
Beowoulf's Avatar
United Nations
http://www.m3forum.net/m3forum/showp...7&postcount=13
Alex
Closed Thread
Why Doesn't My Passenger Side Mirror Tilt in Reverse Anymore? Miami M3 E46 M3 (2001-2006) 17 Thu, Jan-06-2011 07:21:37 PM
Passenger Mirror Reverse Tilt m///tre E46 M3 (2001-2006) 3 Sat, Jul-07-2007 07:04:40 PM
adjusting side mirror tilt (already read FAQ thread) so gti E46 M3 (2001-2006) 17 Sat, May-13-2006 09:50:17 PM
Reprogram Passenger Mirror Tilt Question? t3stman E46 M3 (2001-2006) 1 Fri, Apr-22-2005 04:36:06 PM
Passenger mirror tilt adjustment BoxsterSBoy E46 M3 (2001-2006) 1 Sat, Mar-02-2002 10:34:00 PM
Discussing Adjusting passenger side mirror tilt in the E46 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
