Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E46 FAQ
Old Wed, Aug-08-2007, 10:34:14 PM   #1
F1X3R
Reputation: 0 F1X3R is on a distinguished road
Default **Will Not Stay Running**
Hello all
Here is what happened:
Missed my turn ...swung a very, very sharp U turn
DSC was on and did not let wheels spin - but I pressed the accelerator as to make it whip around quickly, car did not respond to me flooring the accelerator.
My 2002 M3 went about 20 feet and stopped ... it starts back up for 2 seconds then quits out.
Checked the - O2 sensor and its fine , Fuel pump is exact pressure where it should be, no fault code thrown and OBD shows nothing...
Any thoughts or help would be appreciated and good Karma will follow.
Thanks
Jump to top F1X3R is offline   Reply With Quote
Old Wed, Nov-09-2011, 03:11:38 AM   #2
7partsonly
Reputation: 0 7partsonly is on a distinguished road
Default Re: **Will Not Stay Running**
Had same issue turns out the fuel pump relay
Jump to top 7partsonly is offline   Reply With Quote
M3 know-it-alls please stay away from me Goody4 General BMW Discussion 6 Fri, Jul-04-2008 01:58:21 AM
those of you running 245/35/19 & 275/30/19, what tire pressures are you running? IGotId E46 M3 (2001-2006) 23 Fri, Jun-13-2008 11:22:42 PM
For those running just a bbk in the front what are you running in rear? amanr87 E46 M3 (2001-2006) 3 Mon, Jan-07-2008 06:52:45 AM
HELP - Car won't stay running after I changed Cabin Filter! bigneil E36 M3 (1992-1999) 9 Tue, Oct-09-2007 12:30:09 AM
Is the HP here to stay? EMAXX Off Topic 16 Tue, Feb-22-2005 11:54:53 PM
Discussing **Will Not Stay Running** in the E46 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
