Old Sat, Jun-25-2016, 01:25:19 AM   #11
_JohnnyD_
Reputation: 0 _JohnnyD_ is on a distinguished road
Default Re: OEM Plus Eurospec M3 Build
It has 109k kms and was built 12/1993. It looks like the clutch fan was replaced. The hoses look new but the clumps look untouched. It's hard to tell if anything was done before.
Jump to top _JohnnyD_ is offline   Reply With Quote
Old Mon, Jun-27-2016, 02:13:36 AM   #12
frbz
November, december 1993 was the range of the build dates for the 45 Canadian cars. My car was produced Jan 1994
Jump to top frbz is offline   Reply With Quote
Old Mon, Jun-27-2016, 03:39:19 AM   #13
Nate047
Nate047's Avatar
Awesome find!
Old Mon, Jun-27-2016, 09:07:25 PM   #14
NolliM3
NolliM3's Avatar
Congrats on a nice find!
Old Tue, Jul-05-2016, 08:36:27 PM   #15
_JohnnyD_
So I have driven the car a few times and noticed that the coolant temp hits just under mid point on the gage very quickly. About 1 min of driving in my subdivision under 2500 rpm. The ambient temp has been between 70 F and 85 F. I've driven it hard and the temp is not changing. Everything looks like it works fine.
I'm going to do a mini coolant service. I'm thinking fluid, brass drain plug, thermostat, and overflow bottle for appearance. (Maybe I will add a temp sensor for good measure)
All you euro experts what am I missing?
Old Tue, Jul-05-2016, 09:23:16 PM   #16
ZiMMie
Reputation: 0 ZiMMie is on a distinguished road
Germany
gauge has a dead spot, and euro usually warm up faster
#E36S54 #CSLWannabe #TTFS @Mykesf
Jump to top ZiMMie is offline   Reply With Quote
Old Wed, Jul-06-2016, 12:47:33 AM   #17
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
The Euro M engine runs HOT.
No seriously. Whrn I just had my car and opened the hood after a drive, I was like,,I overheated it. Of course I didn't.
It's a high compression 'race'-ish motor. And these headers, will radiate lots of heat.
Hell, after a normal quasi-spirited drive, even the strutbrace is very hot. Don't worry about it. It's perfectly normal.
The Euro M gauge is less buffered. I coded the M buffer in my 328i. I did some tests a few years ago, to test how the needle works. With NCS you can code whatever temp you want to be the centre spot, and at what temp it comes out of it.
Old Wed, Jul-06-2016, 03:53:37 AM   #18
Kirbius
Kirbius's Avatar
Reputation: 0 Kirbius is on a distinguished road
Remember to get the two 38x2.5 orings (i think, double check that) for the thermostat housing to head input manifold (alum tube); the thermostat kit only comes with the bigger main oring
Be good to grab a 316i aux fan switch (80/88) instead of the normal one (90/98 iirc), just have to trim off a small internal tab with the dremel to fit.
Valves clearances, Beisen kit, vac hoses etc on the cards if the maint history is unknown
1996 Evo S50B32 - Boston Green on Modena - Slicktop - Al doors - PDC - JBR 5kg F/W - Clutchmasters FX400 - Mason SS Clutch pedal - UUC Evo3 SSK w/DSSR - PWR radiator - DrVanos o/haul - Full AKG 75D bushing & mount set - AP delete - Fan delete - X-brace - BC Racing C/Os 8k/10k - Whiteline 27mm ARB - ARC8 17x8.5 - Nitto NT01 - APEX 75mm stud - Walbro GSS342 - Schroth Harness - TMS rear control arms - Hawk HP+ pads - GT splitter - GT 4pc wing - Momo Monte Carlo - Racechrono TS - RaceDAC - RR Strut Brace - Proflow PS res + AN lines - VDO gaugeset - E46 330 rack - VAC oil pump upgrade - ARP conrod bolts - Magnaflow spun cats - MAC Motoren Airbox - AlphaN - ATI/VAC HB - 3.91 210 -
Jump to top Kirbius is offline   Reply With Quote
Old Wed, Jul-06-2016, 01:57:44 PM   #19
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Originally Posted by Kirbius View Post
...Be good to grab a 316i aux fan switch (80/88) instead of the normal one (90/98 iirc), just have to trim off a small internal tab with the dremel to fit.
Interesting. Does make me wonder. You'd expect BMW to do so if it was better. But that is an assumption. Lets say the engine is designed to operate at 90, having the fan come on as early as 80 might keep it from getting to optimal operating temp.
Old Wed, Jul-06-2016, 02:16:57 PM   #20
_JohnnyD_
I Googled a few videos showing a temp gage with a bypassed buffer. Mine is definitely buffered because it shows a very consistent temp during the entire drive.
Discussing OEM Plus Eurospec M3 Build in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
