Old Mon, Jan-15-2018, 07:31:29 PM   #1
02_LSB
Default 2002 LSB Re-pair/build thread(ish)
I've had the car for approximately one year, so this is probably an appropriate time to summarize everything that has been repaired or replaced in the last year.
Beisan Vanos Fix
  • S54 Vanos Oil Pump Disk
    S54 Rebuilt Vanos Solenoid Coil Pack
    S54 Vanos Seals Repair Kit
    OE Updated Camshaft Bolts
    OE New Upper Chain Guide
    OE Valve Cover Gasket
    Spark Plugs
    Valve Adjustment
Connecting Rod Bearings
  • OE Upper and Lower Shells
    OE Steering Coupler
    OE Oil Pan Gasket
    OE Engine Mounts
    Power steering lines
Maintenance
  • LiquiMoly 10W60 Oil Change with filter
    Fuel Filter
    Air Filter
    PCV oring
Fluids
  • Pentosin Transmission Fluid
    Clutch Delay Valve Delete
    Rear Differential Fluid
Cooling System
  • OE Water Pump
    OE Thermostat
    OE Temperature Sensor
    OE Coolant
    OE Gaskets
    OE Radiator Fan
Exterior
  • Driver + Passenger rear Window Weather Stripping
    VMR 18" CSL Reps / INDY500 tires
    DEPO Corners
    Unkown Brand reflectors (may change)
    Ebay Carbon Fiber Lip (may change)
    Removed faded window tint
Suspension + Brakes + Clutch
  • Temporary Coilovers
    Rogue Engineering Blue RTABs
    ZCP Rotors and Pads
    OE Clutch replaced by previous owner two years ago
    AC Schnitzer Strut Bar
    10mm spacers upfront
Interior
  • Converted trim to Brushed Aluminum
    ZCP Shiftknob
    Rewrapped A+C Pillars to leather
    AC Schnitzer Parking Brake Lever
    OE Sunglass Tray
    OE Ashtray
    OE Center Console
    Spare Donut Kit
Exhaust
  • Supersprint Race Sections 1+2+3
More
  • RACP Plates
    RACP Bar
    Differential Bushings
    Subframe Bushings
    FCABs
    Transmission Mounts
    CSB
    Guibo
    Diff Fluid with FM Booster
    Shifter Rebuild
    TC Kline Double Adjustable Coilovers
    TC Kline Camber plates
    550F/500R Springs
    Four Pot 996 Brembos
    Epytec adapters
    ECS Brake lines
    Textar Pads
    CSL Rotors
    Bimmerworld Vanos Line
A few random shots... as i get familiar with my DSLR
LSB/Black | 6MT.
Brembo, TC Kline Double Adjustable, Full Supersprint, Beisan, Rod bearings, FX400 Single Mass Kit, AC Schnitzer, RACP plates + Bar + Too much Polyurethane.
E61 daily
Jump to top 02_LSB is offline   Reply With Quote
Old Mon, Jan-15-2018, 09:05:55 PM   #2
Default Re: 2002 LSB Re-pair/build thread(ish)
Nice! What are the width of your wheels and tires? Very square tire wall and meaty look!
Old Mon, Jan-15-2018, 10:19:26 PM   #3
02_LSB
Thanks!
Wheels are:
18x8.5/9.5, Et35/22, 5x120, 72.6mm
10mm spacer up front, need to update first post*.
Tires are:
I will update when I get home.
LSB/Black | 6MT.
E61 daily
Old Tue, Jan-16-2018, 04:17:34 AM   #4
They must be like 255/285 cause my 245/275, notoriously wide PSSs don't look as meaty as your setup and my wheels are exact same spec as yours.
Old Wed, Jan-17-2018, 03:04:53 AM   #5
02_LSB
245/40 front
275/35 rear
LSB/Black | 6MT.
E61 daily
Old Wed, Jan-17-2018, 03:27:47 AM   #6
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
The car looks fantastic, my friend! Can't wait to see how the car progresses
2004 IR Slicktop
Jump to top suaveflooder is offline   Reply With Quote
Old Wed, Jan-17-2018, 03:43:29 AM   #7
02_LSB
Thanks! I donít want it to progress anymore lol -it costs too much.
I plan to have the RACP fixed and... just not fix anymore things for a little while.
Sent from my iPhone using TapatalkIMG_0942.JPGIMG_0943.JPGIMG_0944.JPGIMG_0945.JPGIMG_0947.JPG
LSB/Black | 6MT.
E61 daily
Old Wed, Jan-17-2018, 02:46:42 PM   #8
killa_e46
killa_e46's Avatar
Reputation: 0 killa_e46 is on a distinguished road
Car looks fantastic, you can never go wrong with LSB. Do you have any pics of the interior? I'm interested in seeing those leather wrapped A+C pillars.
Jump to top killa_e46 is offline   Reply With Quote
Old Wed, Jan-17-2018, 03:24:39 PM   #9
suaveflooder
Lol, Iím feeling you at the moment! My bank account is not too happy with the M at the moment
2004 IR Slicktop
Old Wed, Jan-17-2018, 06:55:05 PM   #10
02_LSB
Not the best shots but you get the idea.
I also need to finish the strip that cover the bolts, havenít had time...
LSB/Black | 6MT.
E61 daily
Discussing 2002 LSB Re-pair/build thread(ish) in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
