Old Wed, Aug-12-2009, 10:24:07 AM   #21
doozyj
Alpine White Z4M
doozyj's Avatar
Reputation: 0 doozyj is on a distinguished road
Any update on the delrin piece?
2007 /// Z4M Coupe Alpine White / Light Sepang Bronze 6MT
2003 /// M3 Alpine White / Imola Red SMG II (Sunroof Delete) SOLD
2003 Alpine White M3 - SOLD
http://www.m3forum.net/m3forum/showthread.php?t=322863
Jump to top doozyj is offline   Reply With Quote
Old Wed, Aug-12-2009, 10:29:58 PM   #22
Tonester
Reputation: 0 Tonester is an unknown quantity at this point
Viet Nam
Looking to install it after I get back in town.
Jump to top Tonester is offline   Reply With Quote
Old Thu, Aug-13-2009, 12:41:21 AM   #23
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Wouldn't installing a solid mount like that in lieu of the rubber bushing compromise safety? The stock rubber is supposed to allow for the steering column to collapse in case of a front end crash, so it doesn't go leonidas in your abdomen. Of course we have no way of knowing or verifying this; just throwing out some food for thought.
IMO this is such an easy part to replace, I would just replace it with a fresh OEM one whenever necessary.
Old Thu, Aug-13-2009, 03:45:09 AM   #24
Tonester
Viet Nam
The steering shaft will collapse if there was a case like that.
Over time that will get expensive and time consuming, I think running an aggressive front wheel tire combo as well as driving condition accelerated the wearing of the bushing.
Old Thu, Aug-13-2009, 03:47:53 AM   #25
deilenberger
deilenberger's Avatar
The coupling (that's what it is - not a "damper") is also there to allow for slight misalignment of the shaft and the steering rack shaft. I suspect putting a semi-rigid one in place will result in more force being applied to the input shaft of the steering rack then was intended, with possible bearing/rack failure being the result.
Just MHO..
  • 2011 Lexus RX-350. SWMBO's toy.
  • 2011 Porsche Cayenne Turbo, white/black.
  • 2009 Porsche Boxster, white/blue. My new toy..
Old Thu, Aug-13-2009, 04:38:12 AM   #26
RedM3/4
Default Not to mention potential NHV
On alignment, one car may be fine, by the luck of how all the parts stack up, where the next one could be off. I expect the possibility of vibration as well.
I don't disagree that steering feel and possibly response could be better; all things that make cars more connected are trade-offs for NHV, extra stress on components.
ADS
Just MHO..
06 SMG/ZCP - April 09, MCS 2WR (replaced Dinan over Konis/replaced OE), Supersrpint street section3, RAC RG63, homelink with off-delay, multifunction steering wheel buttons, RacingBrake Front kit.
Old Wed, Sep-09-2009, 09:37:31 PM   #27
jm3
Reputation: 0 jm3 has disabled reputation
FYI, the coupler is like that to prevent the steering rack from being speared into the drivers chest. The steering shaft actually doesn't collapse very much.
All modern cars with a low mounted rack and pinion have a sacrificial mount like that to allow the shaft to completely seperate in a big crash that grabs the (very low mounted) steering rack and pushes it backwards along the underside of the car. Porsches have a particularly elegant solution, starting in the 60's and continuing through today.
There are some very clever solutions for this out there, that still allow the steering column to separate, but they are not publicized.
Jump to top jm3 is offline   Reply With Quote
Old Sat, Jan-15-2011, 11:35:39 PM   #28
///NNM
///NNM's Avatar
Reputation: 0 ///NNM is on a distinguished road
Russian Federation
Default Re: My solution to acheive a more crisp steering response
on the collapsing of the shaft thing...
i was just under the car not long ago to replace my coupling with OEM one.
so everyone knows, the steering column is made out of 3 parts and will collapse with even a slight movement up towards driver in ratio 3 to 1. i could see three parts that collapse in one, moved it myself and was pretty impressed of the design... relax and drive!!!
Jump to top ///NNM is offline   Reply With Quote
Old Sat, Jan-15-2011, 11:57:27 PM   #29
djben
winning.
Reputation: 0 djben is on a distinguished road
Love my Ground Control Urethane / Aluminium hybrid FCABS myself.
2006 BMW E46 M3 SMG - Carbon Black : sunroof delete : Ground Control Street/Track Coilovers : H&R Front Sway: Ground Control Aluminium FCAB : Powerflex RTAB : Rogue RSM : Stoptech 4-wheel BBK : SSR Comp 19" : Bimmerworld Oil Cooler : CSL headers : UUC mid-pipe : Pulleys : Gruppe M Exhaust : AFE elbow/dry filter : 4.10 gears : Epic Motorsports tune : 301 WHP : Recaro Sportster CS : Odyssey PC925 battery
2007 Porsche 911 Turbo 6MT : Hardwired Passport 9500xi : Locking Differential : Sport Chrono Plus : GMG Front/Rear Sways : GMG World Challenge Springs : GMG Toe Links : GMG dog bones : LED DRL : LED Tails : Factory SSK : RSS engine mounts : GT2 Clutch Conversion : Sachs 2.5 Clutch Kit
Jump to top djben is offline   Reply With Quote
Old Thu, Jan-10-2013, 03:00:16 AM   #30
PRYDEREI
PRYDEREI's Avatar
Reputation: 0 PRYDEREI is on a distinguished road
Anyone have tonestors info? I like these delrin guibos
Jump to top PRYDEREI is offline   Reply With Quote
acheive, crisp, response, solution, steering
Discussing My solution to acheive a more crisp steering response in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
