Old Mon, Apr-20-2009, 10:33:49 PM   #41
hottnikkz
hottnikkz's Avatar
Reputation: 0 hottnikkz is on a distinguished road
Would a starter from a 99 M3 fit/work? I know they are different part numbers or look weird but I'm just curious because I have one of those. Thanks.
Jump to top hottnikkz is offline   Reply With Quote
Old Tue, Apr-21-2009, 08:57:23 PM   #42
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
Here is what bay looks like with intake manifold removed on SMG.
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. Sold
1970 911T Tangerine
1972 911T Albert Blue
1970 911E Ossi Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Tue, Apr-21-2009, 09:06:06 PM   #43
hottnikkz
hottnikkz's Avatar
Wow, it does look tight. Does anyone have one for a regular 6 speed?
Old Tue, Apr-21-2009, 10:20:11 PM   #44
Fastdog911
Fastdog911's Avatar
Originally Posted by Boxerj View Post
My 02 M3 SMG is at the dealership now getting a new clutch. I just got an email from the SA that when he got the transmission out, he inspected the starter and all but one of the bolt threads are stripped out.(A previous owner must have had it out) Basically, there is one bolt holding the starter in place. He recommends changing it now to avoid the labor cost of doing it later, and they want $556.44 for the part.
I don't have any problems with my car starting, but I am coming up on 70,000 miles on the car. Is there a general consensus on if/when the starters in these need to be replaced? If I am getting close to that mileage point, I might as well do it now. If I don't replace it, I continue to have just the 1 bolt holding it in place. What do you guys think of the price on the part from the dealer. I haven't researched it yet, but should I go with OEM or our there other brands that are recommended?
Thanks
Fix it now while you have a chance.. I would work out something with the dealer as in that you buy the part from them and they put it in for free.. this is the easiest time to do this work. Mine gassed out at 85,000 miles.
1970 911T Tangerine
1970 911E Ossi Blue
Old Tue, Apr-21-2009, 10:24:36 PM   #45
Fastdog911
Fastdog911's Avatar
Are you meaning you need a photo of the engine bay with intake removed for a 6speed? It is the same thing less the connections you have with the SMG unit.. it would be easier to take the intake manifold off if you dont have SMG as you wont have fluid and or the connection to the fluid tank to deal with. I have detailed photos of the intake manifold with smg removal if anyone needs those to help remove this part... if you plan on it go ahead and buy the clamps that hold the box on to the throttle body.. they can destroy really easy and they are cheap, 3.00 each.. I bought 8 just in case.. I can do a DYI if anyone needs it on how to remove the intake manifold .
1970 911T Tangerine
1970 911E Ossi Blue
Old Tue, Apr-21-2009, 10:29:32 PM   #46
ohnoes
Reputation: 0 ohnoes is on a distinguished road
That DIY would be AWESOME. I am probably going to do this soon, as my car sometimes takes 5 minutes of holding the key in the "start" position to start.
I would really appreciate the DIY. Also, about how long did it take you to do the whole R&R of the starter? I also have 6 speed, not SMG.
Jump to top ohnoes is offline   Reply With Quote
Old Tue, Apr-21-2009, 11:00:19 PM   #47
statepkt
statepkt's Avatar
Reputation: 0 statepkt is on a distinguished road
Yes a DIY would be awesome!!!!!
I saw the first page and thought , why would it be so tedious to just change a starter.
03 Imola Red Coupe
Jump to top statepkt is offline   Reply With Quote
Old Wed, Apr-22-2009, 02:07:13 AM   #48
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Originally Posted by shalend View Post
1. Raise vehicle -- front & rear.
2. Disconnect battery.
3. Remove air housing.
4. Remove air-box, airmass sensor, dipstick-tube & intake housing.
starter is now exposed.
5. Remove wiring from stater.
6. Now go under vehicle. Remove exhaust system - complete [ from manifold to
rear box. Don't foget to remove oxygen sensors wiring plugs]
7. Remove bolts for gear-box cross member. gearbox is now lowered at rear.
8. Remove bolts for stater on bell-housing.
9. Stater is now loose.
10. Remove stater from engine bay side.
NB. Make sure locating pin on gear-box bell-housing is alighned with stater & tighten bolts evenly , when assembling.
Oh my.
I have done starters on E46 non-M without removing anything but some underpaneling, a little bracket that's on the way and the starter itself. I can't see why you'd have to remove all that stuff on the M3 unless the starter is at a totally different location.
Old Wed, Apr-22-2009, 10:47:15 PM   #49
Fastdog911
Fastdog911's Avatar
look for a DYI post shortly on how to remove Intake Manifold
1970 911T Tangerine
1970 911E Ossi Blue
Old Mon, Apr-27-2009, 09:39:06 PM   #50
hottnikkz
hottnikkz's Avatar
Makes sense, just didn't know how bad the situation was with smg vs 6 speed. I have a 6 speed but looking at the pics I can make out the smg lines vs non. So thank you very much for the preview.
A DIY would be absolutely amazing.
motor, removal, starter
Starter removal/installation DIY tilolite E46 M3 (2001-2006) 12 Wed, Dec-16-2009 08:07:18 PM
starter removal plz help!!! andresvillanu20 E36 M3 (1992-1999) 12 Wed, Sep-03-2008 08:13:25 PM
fs: M3 starter (new, never used) Benihana E36 M3 (1992-1999) 3 Sun, Sep-17-2006 11:33:23 PM
Thread Removal and Notifying The Thread Starter E90_GEN Member Notes and Requests to Admin/Mods 5 Sat, Feb-19-2005 07:19:47 PM
M3 Starter miduso E36 M3 (1992-1999) 6 Wed, Feb-19-2003 08:43:30 PM
Discussing Starter motor removal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
