Old Wed, Dec-27-2017, 06:28:56 PM   #781
Default Re: MSS52 / MSS54 / MSS54HP Binary Modification Tool
Martyn, will your tool know if any of the settings have already been changed from stock? To put it another way, if I already have the speed limiter removed and I open up your program and my partial read, will your program display that the 155mph limiter is already deactivated or not? If not, I guess I could select it and it wouldn't ruin anything right?
Thanks
_
Old Wed, Dec-27-2017, 07:47:27 PM   #782
rjskalet
Reputation: 0 rjskalet is on a distinguished road
Thanks
Yeah that is correct. It will show a check mark next to it
Jump to top rjskalet is offline   Reply With Quote
Old Thu, Dec-28-2017, 06:47:48 AM   #783
kmn
Reputation: 0 kmn is on a distinguished road
Finland
Originally Posted by SHRMN8TR View Post
Thanks @MartnyT. Works great! Read every page of this thread, keep it up! Would like to know when the we can tune the idle speed (I have a single mass flywheel, would like to see if I can quiet down that chatter during city driving)?
This can be done for some four-five different temperature areas by hacking the hex bin, but not through Martyn's tool. I've done this to my own car. On cold start, it first idles at 1300rpm, then at 1150rpm, then 1000rpm and lastly the stock 890rpm (or whatever it was). Can't remember to be exact, but it's still there.
Btw, anyone else saw Buildjournal posting about their E46 M3 6 speed manual launch control to be included in their B-spec tune?
My car: BMW E46 M3 -01 Imolarot 2
Daily driver: BMW E87 118d -06
Ex cars: E36 328i Coupe -92, E91 320d Touring -06, E36 328i Touring -96, E36 325i Cabriolet -93, E39 528iA Touring -97, E39 535iA Sedan -98, E36 320i Touring -95
Jump to top kmn is offline   Reply With Quote
Old Mon, Jan-01-2018, 06:17:46 PM   #784
SHRMN8TR
Reputation: 0 SHRMN8TR is on a distinguished road
Hey Guys, could use some help. Took my car in for the airbag replacements but there was also a new fw update for some o2 sensors(?). I’ll find the actual recall when i get back home.
TLDR: went to reflash my car. BMW looks like they fw locked my car now to their fw or newer. I can’t edit the bin.
I also can’t downgrade and use the stock fw or flashed fw.
Jump to top SHRMN8TR is offline   Reply With Quote
Old Mon, Jan-01-2018, 06:21:35 PM   #785
SHRMN8TR
DME reprogramming for catalytic conversation Recall campaign 08E-A03 May 2009.
Edit: I suspect it's the ecuworx tool and the new DME version incompatiability (?), checking with Martyn now.
Old Tue, Jan-02-2018, 08:34:45 AM   #786
MartynT
MartynT's Avatar
United Kingdom
The BMW software hasnt been updated for a long time, my tool caters for all of available versions.
Can you send me a partial?
Jump to top MartynT is offline   Reply With Quote
Old Tue, Jan-02-2018, 08:37:02 AM   #787
Giohb777
Giohb777's Avatar
Reputation: 0 Giohb777 is on a distinguished road
Lebanon
I've successfully swapped my car from SMG to 6MT, and flashed the 6MT software.
But SMG Shift lights are not working, although i enabled them from the tool.
How to fix that?
Jump to top Giohb777 is offline   Reply With Quote
Old Tue, Jan-02-2018, 08:39:06 AM   #788
MartynT
MartynT's Avatar
United Kingdom
Either your cluster doesn't support them, or you haven't completed all the required wiring in the SMG to Man swap.
Old Tue, Jan-02-2018, 08:40:23 AM   #789
Giohb777
Giohb777's Avatar
Lebanon
My car is 09/2003
Which wiring is required for SMG Lights ?
Old Tue, Jan-02-2018, 08:42:44 AM   #790
MartynT
MartynT's Avatar
United Kingdom
Originally Posted by Giohb777 View Post
My car is 09/2003
Check through the SMG to Manual swap thread.
Discussing MSS52 / MSS54 / MSS54HP Binary Modification Tool in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
