Old Fri, Mar-17-2017, 02:41:23 PM   #1
SG/IRM3
Flyguy
SG/IRM3's Avatar
Reputation: 0 SG/IRM3 is on a distinguished road
Default MCS Install Question
My MCS 2WNR are being delivered today and I took a look at their website's install instructions. They warn not to use an impact tool to tighten the first top nut which sits against the brass nut on the rebound adjuster. My experience with my AST suspension and Vorshlag camber plates was that you couldn't get their top nut tight enough to avoid clunking without an impact. Vorshlag says they use an impact on all of their MCS installs. I'm aware of the proper use and cautions when using an impact but wondered if anyone can provide first hand experience with regard to using/not using an impact tool on the top nut?
Mike K.
2005 M3
Jump to top SG/IRM3 is offline   Reply With Quote
Old Fri, Mar-17-2017, 02:47:51 PM   #2
ThunderMoose
Default Re: MCS Install Question
for the record I used impact.
My recommendation is prior to install, make sure that rebound and compression can be adjusted freely. Then put them in the middleish settings. I had to buy a thin 7/8" wrench to get the second nut tightened.
#67 2017 NASA TX TT3 Champion
Old Fri, Mar-17-2017, 03:02:28 PM   #3
SG/IRM3
Flyguy
SG/IRM3's Avatar
Thanks for the reply! I'll follow your recommendations and was wondering what size thin wrench I would need.
Mike K.
2005 M3
Old Sat, Mar-18-2017, 02:55:55 AM   #4
10speed
Reputation: 0 10speed is on a distinguished road
I use an impact driver. It really only has the capability torque to about 60ft/lbs when you let it hammer away. When I install the first nut, I just let the driver hit it a couple times and its enough to snug it down without over torqueing. After that, 7/8's thin wrench and the same process for the 2nd jam nut. Works well.
Jump to top 10speed is offline   Reply With Quote
Old Sat, Mar-18-2017, 03:11:17 AM   #5
SG/IRM3
Flyguy
SG/IRM3's Avatar
After looking at them an impact should be no problem. Need to source a thin wrench tomorrow so I can get them installed. Your method sounds good. These things look almost too good to put in the wheel well though. Quality pieces.
Mike K.
2005 M3
Old Tue, Mar-21-2017, 02:02:24 AM   #6
SG/IRM3
Flyguy
SG/IRM3's Avatar
Finished the install with the only remaining item being the lower rear shock bolt. Does it require a washer? The stock shock doesn't require one since it has a built in plate on the lower mount and the washer from my old ASTs is too large and hits the shock body before the bolt is fully seated.
I did see in another thread that Thundermoose did not use a washer? Any other feedback?
Mike K.
2005 M3
Old Tue, Mar-21-2017, 02:38:35 AM   #7
ThunderMoose
If you find a washer let me know. I will say that mine has held up for last 2+ years without one.
Old Tue, Mar-21-2017, 02:52:17 AM   #8
SG/IRM3
Flyguy
SG/IRM3's Avatar
Will do - thanks.
Mike K.
2005 M3
Old Tue, Mar-21-2017, 03:33:29 PM   #9
SG/IRM3
Flyguy
SG/IRM3's Avatar
Confirmed with Jason McDaniel at Vorshlag that no washer required on rear lower shock bolt.
Mike K.
2005 M3
Discussing MCS Install Question in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
